Home > General > cd changer |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi mate, was reading... if you fit the bmw cd changer it will play mp3's and give you cd text..all the connections are the same but looks a bit of a big job to swap the unit..can any one confirm this with the bmw changer
27th Oct 2009 10:09pm |
shaun10569 Member Since: 20 Oct 2009 Location: lancashire Posts: 13 |
sounds like mine when i got it , the lift mechanism gets bent due to the cartridge getting stuck ,can be fixed but may happen again i was told so i bought one from a bmw (same unit with a different front) fitted straight in an all ok, jusr check the plug on the rear as there are 2 types. good luck......mine was only 60 of ebay too |
27th Oct 2009 10:12pm |
did your new one play mp3"s. and give you cd text. |
27th Oct 2009 10:29pm |
no as i just got the earlier type but it does play cd/rw, i was'nt interested in the cd text etc |
27th Oct 2009 10:43pm |
scotty7 Member Since: 27 Oct 2009 Location: lanarkshire Posts: 65 |
cheers folks,
28th Oct 2009 9:28pm |
Sounds as if you have a loose connection somewhere |
29th Oct 2009 8:42am |
