Home > General > Dash Top Fitment
mjdronfield
Dash Top Fitment
It may be me, and I may be becoming paranoid, but I've a suspicion that the top of my dash seems to "come up" to go over the screen.
When I look at pictures online, the dash top seems to be more straight, if you see what I mean.
Is it possible to remove it and put it back on better ?
Cheers
Mark
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #118461 20th Apr 2012 4:14pm
i kinda see what you mean, irritating as it may be is it worth trying to take it off and possibly breaking something? There is nothing that can't be fixed with a hammer😜😜
Post #118463 20th Apr 2012 4:29pm
fisha
Do all the vogues from that era have a stitched leather top dash?
I have an HSE, and its not leather topped, just wondering if its a stadard trim for the vogue.
If it isn't, and thats an after market covering, then its possible the dash hasn't been sat back down properly. the top dash slides forward into slots, and then is held in place by the bolts you see on the top of it. Possible that its not slotted correct?
That being said, from my experience, the dash either fits into place or doesn't with very little inbetween. V8 or else ...
Post #118466 20th Apr 2012 4:57pm
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Yes... Thumbs Up
Post #118470 20th Apr 2012 5:09pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
It's fairly easy to remove, find the PowerfulUK video on Youtube and it's all there. As I recall, you pull it towards you (ie front to back) to get it off, so perhaps yours has been off and not properly re-seated?
Post #118474 20th Apr 2012 5:24pm
that looks pretty easy actually.
http://www.youtube.com/watch?v=jSYo175Q6mk There is nothing that can't be fixed with a hammer😜😜
Post #118477 20th Apr 2012 5:31pm
mjdronfield
Many thanks.
Just watched the video.
I'll prob have a look over the weekend, but imagine that maybe I'll have to get the dashtop straight by taking it off and leaving it with something sat on it.......
........I may be lucky and it goes back better.
We shall see...........
All the best
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #118498 20th Apr 2012 7:12pm
fisha
more likely that would squash the leather / foam V8 or else ...
Post #118515 20th Apr 2012 8:37pm
SteveMFr
Site Sponsor
Normally the dash pad is held down by numerous hooks un the bottom of the pad that slide into appropriate slots on the (very complex) under dash structure as well as the large torx screws.
Almost looks to me as if whoever R&R'd the pad either missed several of the slots so that the hooks are now on top of the under-dash structure rather than in the slots or several of the hooks are broken and the dash is warping in the heat of the sun.
Either way, the only way to repair is to R&R...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #118741 23rd Apr 2012 10:29am
mjdronfield
I was hoping that there was some sort of clip that had been missed, or rested on top of.
Ended up out all weekend, so will investigate next weekend........
Thanks for your input.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #118764 23rd Apr 2012 2:58pm
mjdronfield
I've just spent a few hours removing and refitting the dash top, and the end result is that the dash is pretty much in the correct position now.
The worst bit of the job was removing the face level vents from the end caps.........about 40 mins for the drivers side !!
The centre section of dash clipped back into place properly and the refit began......
Thanks all.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #119473 28th Apr 2012 3:23pm
well done Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #119474 28th Apr 2012 3:34pm
