Home > Technical (L322) > Clock resets itself, presets dissappear?
Odd one....
Got into the car and for some reason the clock had reset itself, forwards 35 mins.
??? Question
Anyone else had this or know the cause. Hadnt touched the clock setting buttons or removed battery etc.
The only thing different i had done was tow with it.
Also it had forgotten all of the radio presets. Strange. There is nothing that can't be fixed with a hammer😜😜
Post #117048 10th Apr 2012 2:27pm
Had you swapped keys? I have different presets on the radio from my wife, we have our own key and it remembers the presets for each key. Can't help with clock sorry... Someone will suggest battery I'm sure! Previously..
Post #117051 10th Apr 2012 3:03pm
I did swap keys to open it but didnt start it with them the other day, however as you say doent explain the clock gaining 35 mins unless the key remembers the clock as well, also if the battery was low would it not run slow?
Bit weird.[/b] There is nothing that can't be fixed with a hammer😜😜
Post #117067 10th Apr 2012 4:47pm
modbarra
Scotland 2019 Range Rover Autobiography 5.0 V8 Loire Blue
hi, had similar prob recently.... took out clock fuse, waited for time lapse and replaced fuse..
Post #117088 10th Apr 2012 6:43pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
yes, i am not going mad. Last year my clock indicated about 1hour faster. Thought it may be some thing with the keys and going back to the UK (time difference). But i was sure that i didn't change the clock or use a different key.......So yes this has happened once to me - why?, i don't know.
Post #117108 10th Apr 2012 8:37pm
Any update on this guys?
Post #121064 9th May 2012 8:35pm
Putting it down to keys, if i open it with the spare key, but dont start it, lock it up but then open it with my main key then everything on the radio presets disappear, clock is different, but i reset it last time when using the spare key so time doesnt change now. There is nothing that can't be fixed with a hammer😜😜
Post #121070 9th May 2012 8:53pm
killatomato
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Yes mine does this every time I use my key after the missus drives it before me. I asked everyone about this, but no one knows what's the problem.
Post #121280 11th May 2012 7:03am
Including the clock changing?
Post #121281 11th May 2012 7:22am
the clock changing is due to someone messing with the time vortex continuum gary... Wink ... - .- -.
Post #121291 11th May 2012 8:28am
Thelord67
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Mine does this when I change the key, very annoying...
Post #122724 20th May 2012 6:31am
