![]() | Home > Technical (L322) > Clock resets itself, presets dissappear? |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Had you swapped keys? I have different presets on the radio from my wife, we have our own key and it remembers the presets for each key. Can't help with clock sorry... Someone will suggest battery I'm sure! Previously..
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I did swap keys to open it but didnt start it with them the other day, however as you say doent explain the clock gaining 35 mins unless the key remembers the clock as well, also if the battery was low would it not run slow?
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
hi, had similar prob recently.... took out clock fuse, waited for time lapse and replaced fuse.. |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
yes, i am not going mad. Last year my clock indicated about 1hour faster. Thought it may be some thing with the keys and going back to the UK (time difference). But i was sure that i didn't change the clock or use a different key.......So yes this has happened once to me - why?, i don't know. |
Any update on this guys? |
Putting it down to keys, if i open it with the spare key, but dont start it, lock it up but then open it with my main key then everything on the radio presets disappear, clock is different, but i reset it last time when using the spare key so time doesnt change now. There is nothing that can't be fixed with a hammer😜😜
killatomato Member Since: 15 Jul 2011 Location: Wirral Posts: 41 ![]() ![]() ![]() |
Yes mine does this every time I use my key after the missus drives it before me. I asked everyone about this, but no one knows what's the problem. |
Including the clock changing? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
the clock changing is due to someone messing with the time vortex continuum gary... |
Thelord67 Member Since: 19 May 2012 Location: Stockport Posts: 27 ![]() ![]() ![]() |
Mine does this when I change the key, very annoying... |
