Home > General > Does anybody know if...?
Nogbag
Re electrically operated / adjustable steering wheels which do seem sometimes to be problematic and maybe an expensive fix I wondered if, once a satisfactory postition had been found, whether it is possible to leave it locked in that position (maybe take a fuse out?) so that it remains stationery when the ignition key is removed/inserted. (I have'nt yet found my 'perfect' L322 - the search contines - otherwise I would try it myself.
Post #116712 7th Apr 2012 8:29am
supershuttle
Mines the same but just when it auto adjusts to facilitate easy entry and exit of very fat people (I say this because I'm no circus dwarf) - it auto lifts to it's highest tilt position. I am eagerly awaiting the ability to disable this feature which i understand this is on the development map for the IIDTool which I have.
Others have just pulled the wires off the motor but this doesn't help if you actually need to move the wheel up and down - assuming you let other people drive it.
Also it's worth noting that you can stop the auto movement of the wheel by just dabbing the adjuster when it tries to move.
I've never had the problems others have recorded on the forum with tabs breaking off etc and control always seems to return on the next start up - odd! Geoff
Post #116715 7th Apr 2012 8:53am
Simply set it and unplug one or both of the motors behind the cowling... Simples...
Craig Thumbs Up
Post #116716 7th Apr 2012 8:55am
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
As Craig says..............or turn it off in the settings using Autologic. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #116726 7th Apr 2012 9:35am
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
I've disabled it using All Comms, however it's good practice to manually move the adjuster once in a while to stop the motors from sticking Thumbs Up
Post #116742 7th Apr 2012 12:17pm
Nogbag
Thats great folks, thanks. One less thing to worry about when I eventually get one!
Post #116749 7th Apr 2012 1:29pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
On the MY12 FFRR this action is disabled by turning the adjusting toggle off auto. Sorry I cannot help for earlier models, although a check on TOPIx should explain in the owners handbook.
Post #116754 7th Apr 2012 2:28pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Mine only work manually, they stay where they are unless I adjust anything. Which suits me fine as I'm the only person who drives my car. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #116761 7th Apr 2012 4:21pm
best thing i've done ..i used the RAC ... ... - .- -.
Post #116767 7th Apr 2012 5:51pm
They only move automatically on the 02-06 cars... Facelift cars dont...
Craig Thumbs Up
Post #116770 7th Apr 2012 8:55pm
Really ? 2008 MY Supercharged
Post #116771 7th Apr 2012 9:02pm
oldcro
Craig Thumbs Up
They do on mine, but you do need memory seats obviously.
Post #116772 7th Apr 2012 9:09pm
Automatically goes in and out of the dash when you put the keys in and out of ignition on early models... Not meaning when you press memory buttons on seats...
Craig Rolling Eyes
Post #116773 7th Apr 2012 9:22pm
Mikeyjd
Mine's a 2003, the steering wheel only moves if I alter the controls. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #116781 7th Apr 2012 11:51pm
And mine is a full 2008 model ( words not symbols around the touch screen ) and my steering wheel moves on putting the key in or out so it looks more like Land Rover is playing the" Some you do and some you don't" game . 2008 MY Supercharged
Post #116783 8th Apr 2012 7:00am
