Home > Technical (L322) > TMC not functioning? |
How's your Clasic FM reception? TMC info is only broardcast by them, I can't get it here so no TMC but as I get toward Glasvagas it kicks in. 2008 MY Supercharged
12th Oct 2009 8:48pm |
Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142 |
Hi all first post!
13th Oct 2009 2:02pm |
Soupdragon Member Since: 24 May 2008 Location: Norfolk Posts: 57 |
Thanks both for the replies.............Stocky I think you may be right although it seems odd that the instructions appear in the handbook (which is for the home market). Oh well, I try not to use satnavs unless I really have to.
14th Oct 2009 8:31am |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I'm on a '56 plate and my TMC uses Classic FM as its source. I had a problem recently where the TMC icon on the Sat Nav had a red cross through it as though it wasn't receiving data, so went to dealer who did a 'hard reset' on it and all OK again. Don't knwo whether this info helps at all but just thought I'd let you know
19th Oct 2009 4:54pm |
wardpg Member Since: 26 Jul 2008 Location: Preston Posts: 76 |
I have an 08 ffrr and tmc is always a problem, keep losing it even though i get perfect reception from classic fm . try to search for it and sometimes it works but most of the time cant find it ,drives me up the wall. Same thing happened with my previous D3. My son has a audi A4 it works perfectly on his -suspect its where LR put the Aerial. |
19th Oct 2009 10:54pm |
