Home > Technical (L322) > Unsure of noise coming from front tyre / wheel / road?
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Hi, over the past week i have noticed a noise that sounds like the noise when you have brand new tyres on with the stickers still attached and they make that paper kinda noise on the road. It sounds like it comes with every repetition of the wheel - also the brake disks are not hot etc so cant be brakes sticking /rubbing?
It is making the noise all the time (every rep) and the engine drowns the noise out over 30 mph unless coasting down hill etc. The noise doesn’t go - lessen - or get louder if i turn a corner or brake !
I do need to have the window down to hear it properly. I’ve checked tyres and no screws or stones in them but they do only have 2mm left before the minimum limit line. Tyres are Pirelli scorpions.
Gunno have to ring garage me thinks....just wondering if anyone has had this or similar before to point me in the right direction and what to look for. Also thinking of swaping tyres around and putting the good spare on just to eliminate the tryes.
Any ideas? 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #113892 19th Mar 2012 8:10pm
spanner
Hi i had similar noise last year turned out to be debris in the tyre search me how it got there but thats what it was
Post #113895 19th Mar 2012 8:18pm
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Worth popping off your wheel centre caps with a flathead screwdriver and checking there is nothing back there.
I changed mine recently and there was a load of gravel in the OSF for some reason!
Post #113898 19th Mar 2012 8:25pm
wedgel322
Hopefully that may be it? Will take it for tyres swapping around 2mora. I just start thinking the worst and imagining that its going to be some expensive drive related thingy or 'whats 'a' ma call it' that will skint me out ! 2003 Range Rover HSE 3.0 TD6
Post #113899 19th Mar 2012 8:26pm
