Home > Wheels & Tyres > Rear Tyre Wear
Rear Tyre Wear
My grabbers are starting to show signs of wear on the outer edge, just like the Nexens did on my 20" a while back.
First thought is to switch the tyres to the other side (that means tyre of one wheel and onto the other wheel to keep rotation correct) - this should give me more time.
But will a 4 wheel laser alignment sort this out, or is this something more fundemental - e.g. a need to replace parts at the rear? .
Post #111552 7th Mar 2012 6:55pm
Sounds like a bush has gone somewhere.
I think this is common on x5's and they share a few mechanical parts with your ffrr Joe.
Maybe get a free landrover health cel and see why it throws up Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #111556 7th Mar 2012 7:09pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Think it may be worth checking toe angle if the edge is smoothly warn, if it's "scalloped" could be trailing arm bushes or similar.
Run your hand round the warn part and see if you can feel inconsistencies.
Post #111559 7th Mar 2012 7:12pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Sounds like wear in the toe control arms.
Post #111570 7th Mar 2012 7:28pm
