Home > In Car Electronics (L322) > Speaker upgrade
Lee's Dad
Vatican
Did you learn all your skills from your dad, Grasshopper Question Wink
Post #110412 1st Mar 2012 10:54pm
daveo
hi pretlove, the new speaker you have fitted is a 3way unit, it the the speaker you replaced it with a mid/low range, V8 facelift Range Rover Autobiography 22" wheels.
Post #110418 1st Mar 2012 11:34pm
pretlove
grass hopper Rolling with laughter no my pa doesn't get his hands dirty now days unless he is cleaning his balls .....golf balls that is Wink
daveo i think the speaker i removed was mid to low yes ....i take it by your reply thats gonna cause me problems Confused
they sound ok but the rear speakers have more bass "RANGEISM WILL NOT BE TOLERATED"
Post #110420 1st Mar 2012 11:46pm
daveo
not sure, just thought if your crossover is pushing mid to low to the door speaker there will be no high range for the tweeters, will it distort the high range, what was the impedance of the ones you removed 4 ohm's, not sure it will make any difference but as you have made a neat job of fitting them, would not want them to cause probs with your amp... V8 facelift Range Rover Autobiography 22" wheels.
Post #110423 1st Mar 2012 11:56pm
In my last 04 FF i put the speakers from an 08 VSE Harmon Kardon system including the Sub Woofer (used and rewired the wiring from my sub box) and it was a massive improvement...
Craig Thumbs Up
Post #110427 2nd Mar 2012 1:08am
pretlove
@ daveo ill double check later
@craig I was tempted to fit the sub from a later rr but wasn't sure I it would be that straight forward "RANGEISM WILL NOT BE TOLERATED"
Post #110436 2nd Mar 2012 7:05am
mjdronfield
I must admit to being a little disappointed with the standard stereo in my Vogue. Gone from the Harman Kardon setup in a Disco 2 ES, and have a LINN system at home.
It just sounds a bit "flat", but then the "M Audio" setup in a 2001 M5 only sounded reasonable, so I wonder if the standard OEM BMW stuff is just like that.
May finish up with the amp upgrade yet........
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #110517 2nd Mar 2012 3:57pm
farmercowley
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Was your door card easy to remove? I'm tempted to get some 6 inch fly component speakers so I have separate tweeters to replace and pretty much do what you have there, how was your outcome? Would you say it's worked as you wanted it? Cheers
Post #434994 15th Apr 2017 8:53pm
farmercowley
Do any of you guys no if it's safe to take the power off the live wire in the boot for an aftermarket sub?
Post #434995 15th Apr 2017 8:55pm
mikeyyn
Not sure about the speakers but it not too hard to take the door card out, I needed to replace a wing mirror.
Videos on You tube show you how.
Post #435025 16th Apr 2017 9:53am
