Home > General > metal dust caps
daveo
metal dust caps
Censored Censored metal dust caps, bought a set of the polished dust caps with the little grub screw to stop them going walk about, any way went to check the tyre pressure and do you think one of the little Censored would come off...no not one, all stuck fast. so apart from having the valves replaced any ideas on how to get the things of, if you have them on your car best have a check to make sure they are not stuck on like my ones.. V8 facelift Range Rover Autobiography 22" wheels.
Post #108551 22nd Feb 2012 12:22am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Seems odd how quickly they have got stuck - I mean they are removed every week as part of the weekly checks of vehicle safety... Rolling with laughter Rolling with laughter
Post #108558 22nd Feb 2012 8:02am
a soak in wd40 might work...
having 22 years in the tyre trade i have never ever been a fan of metal valves or metal valve caps..rubber every time for me. ... - .- -.
Post #108559 22nd Feb 2012 8:10am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Had them fitted to my discovery, siezed solid all you can do is grip as gently as possible below the valve cap with a pair if grips as you undo and hope a bit of rag or card should stop you damaging the stem of the valve if not ATS i am afraid. Smear them with copper slip.
The ones that came fitted to the RR seem ok but fave a small o ring in them?
good luck Mine was a blue one! Smile
Post #108560 22nd Feb 2012 8:10am
ric355
I learned many years ago that metal valve caps are a really bad idea. Plastic every time for me.
Post #108609 22nd Feb 2012 1:36pm
daveo
they are stuck fast, dont want to force them to hard but i think i will have to, have to wait till the weekend and have the wheel off, V8 facelift Range Rover Autobiography 22" wheels.
Post #108642 22nd Feb 2012 4:17pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
dont do it, i been through quite a few packets of metal ones, little feckers round my way like to nik them and stick them on thier bikes
Post #108643 22nd Feb 2012 4:26pm
sleepezy
It's a chemical reaction between the different metals in the cap/stem, essentially accelerated corrosion. Sounds bad Sad
Post #108644 22nd Feb 2012 4:27pm
daveo
i thinks its a date with the dremmal Crying or Very sad V8 facelift Range Rover Autobiography 22" wheels.
Post #108651 22nd Feb 2012 5:27pm
Googsy
not like you to get caught out Daveo
Cutting disc would work all you would have to do is remove very top of cap and then should come off easily
or
what about a blowtorch (cooking version) might be able to get the cap to expand with heat if used gently ?
or
Also a hairdryer to expand valve might be gentler than above option then remove using one set of pliers or similar to hold valve and other to remove cap.
Best of luck Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #108653 22nd Feb 2012 5:37pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Tut I just fitted my transformer ones, hope they don't get stuck Shocked
Post #108683 22nd Feb 2012 9:18pm
Googsy
Jeez Lolo they sound awful.... Shocked Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #108695 22nd Feb 2012 10:12pm
daveo
i think the next set will have to be the ones with the nylon inserts..first set lasted a week, 3 out of the 4 went missing in sainsburys car park,so the next set had the little locking grub screws, never lost any but i bet they tried..so just a warning to all that may have them,get a bot of copper eze on them or get rid before the stick fast.. V8 facelift Range Rover Autobiography 22" wheels.
Post #108698 22nd Feb 2012 10:23pm
Lolo
Each to their own I say.. Haters gonna hate.. Razz
Post #108700 22nd Feb 2012 10:24pm
Googsy
I'll know your RR when I pass it then ! Each to their own your right Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #108795 23rd Feb 2012 1:10pm
