Home > General > metal dust caps |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I am sure Land Rover issued a service bulietin about not using metal valve caps with metal valve 56 TDV8 Vogue SE
23rd Feb 2012 1:11pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 |
If I hadn't read this post, if I hadn't drank a few glasses of wine, I would have left my metal dust caps alone, but NO I read the post got 3 off with pliers and broke one (but still got it off) new ones are on order - still metal - but will be applied with copper slip and hope that makes a difference Geoff |
23rd Feb 2012 5:50pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16305 |
I believe expensive ones have brass inserts so dont stick!
24th Feb 2012 12:07am |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 |
I have the ones with a built in led that flashes if the pressure drops . I put a smear of vasalene on the threads before I put them on.... |
24th Feb 2012 1:55pm |
I know this is an old thread but just an update one of the new metal ones stuck fast (got it off with molegrips) so now all the lot are plastic (about a quid on eBay) Geoff |
8th Oct 2023 5:01pm |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 184 |
Last time I was in my local tyre fitting centre, I asked the guys if they had any spare tyre valve caps and the guy said help yourself. They had a tray on the tyre removing machine and they unscrewed the caps and threw them in as they change valves when fitting new tyres. I got a handful of black and also silver grey which BMW typically use.
8th Oct 2023 6:22pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I have locking ones to deter the 'tyre extinguishers' but fitted them with silicone grease on the threads and never had a problem removing them. 2012 TDV8 Vogue (L322) |
9th Oct 2023 10:22am |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 |
Spawn of the devil , having had to try (sometimes successfully and sometimes not on customers cars) I'd never use them on anything I own . |
6th Dec 2023 12:11am |
A smear of Vaseline works perfectly... |
6th Dec 2023 12:26am |
