![]() | Home > In Car Electronics (L322) > anologue clock |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
when you set the digital on the screen and then press 'ok' , the analogue should spin to the set time, if not then its a dealer job. ... - .- -.
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
Thanx.. Not working in usual set up mode.. It has remained 40 mins ahead of gmt. So constant, any way of stopping power to it, ie fuse, for 40 mins then connecting? Save a trip to dealers! Thanx |
you could try a battery dis-connection....wait 20 or so minutes then re-connect..remember to turn the steering wheel fully left ,then right.. ... - .- -.
steering wheel left/right? thanx |
mentioned many many times....but when you re-connect the battery the steering parameters must be set otherwise you will get dashboard errors..
thanx |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I had this with my 2010MY - Dealer fixed it under warranty either by resetting it or replacing it - sorry I cant remember which |
Thanx, |
ok..... no 40 fuse removed (anologue clock), waited 40 mins, the time difference, and replaced it or tried to.. dropped it! |
result.. |
