Home > In Car Electronics (L322) > Light error message when they are working
Reformed
Just been out in the car, and suddenly I got the check sidelight/tail lights error come up, along with a fast flashing indicator.
Pull over to check, all lights are working, allthough the indicator is flashing quickly. It seems to clear itself, then start telling me to check when they are working.
It has worked fine up until now, and they are normal bulbs.
Cant see anything obvious as to why it bongs and asks to check lights and then work ok again?
Anyone had this? Reformed
Post #99720 29th Dec 2011 8:32pm
Poor connection in the bulb holder possibly? Shocked
Post #99722 29th Dec 2011 8:37pm
what john said, loose wire or dodgy bulb holder.. ... - .- -.
Post #99729 29th Dec 2011 8:48pm
Reformed
Checked all that and they are all tight Shocked
Ive noticed with the indicaters they flash normal without the lights on, but with the lights on they flash fast, and they are all dry as well so I cant blame the rain?
Could it be undervoltage glitches?
I do sometimes get the HDC error on startup, so I am thinking my battery? Reformed
Post #99730 29th Dec 2011 8:53pm
if the battery is 3 years or so old then it could be that.....i get the check light error on mine now and again but it all works ok. ... - .- -.
Post #99733 29th Dec 2011 9:03pm
Poor earth somewhere Thumbs Up
Post #99736 29th Dec 2011 9:11pm
Reformed
Well its started raining again now, so I have left my fiddling!
Hopefully if its dry in the morning, I will pop to eurocarparts, get a new battery, then change that and clean the earths at the same time, see what that does.
I have no idea how old the battery is, it was in there when I got it. Reformed
Post #99745 29th Dec 2011 9:38pm
Martin
Site Admin
You're not using LED bulbs are you?
Post #99748 29th Dec 2011 10:04pm
Reformed
The number plate lights and side lights are LED, but they have been in now for about a year, and its never played up before. Reformed
Post #99749 29th Dec 2011 10:10pm
mine are leds as well ,hence the occasional error... ... - .- -.
Post #99764 30th Dec 2011 10:00am
Reformed
Well the new battery is all fitted, (that is a tight fit!!!) but the indicators still flashes quickly on both sides Big Cry
When the lights are off they work normal but with the lights on they blink normal, then fast.
All the lights are working as they should.
I am wondering should I leave it and put it down to damp/wet as we have had a bit of rain recently (allthough I checked for water in the rear compartments/spare wheel and lights, all is dry except some slight condensation in the drivers side light unit - the passenger side is a new unit).
EDIT- All sorted Thumbs Up Reformed
Post #99796 30th Dec 2011 1:25pm
