Home > Technical (L322) > MOT Question |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
whats the mileage on the car, if it is very low and you are concerned start by looking for a small black dot in the lcd display next to the mileage this will tell you that some thing is a miss,,,,
28th Dec 2011 8:00pm |
Never seen that before
28th Dec 2011 8:01pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
Are all the pixels working on the dash? Mine got so bad I could not read the mileage at all, so I had mine repaired before the MOT.
28th Dec 2011 8:26pm |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 |
blimey that was quick.
28th Dec 2011 8:29pm |
The black dot is a sign that somethings been tampered with. It could mean something innocent but likewise, could mean the mileage has been "corrected" Reformed |
28th Dec 2011 8:48pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
From my knowledge it would be very hard to clock one of these cars. The mileage is stored on so many different ECU's it would take a wizard and a far bit of money to change. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
28th Dec 2011 9:18pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Several ECUs store the mileage. The black dot means that the mileage as stored in each of these ECUs do not match ie at least one is different. The display then shows the highest of the stored readings. May be innocent (eg an ECU replaced and not sync'ed) or not. Graham
28th Dec 2011 9:47pm |
IIRC you can check old MOT's online for a car with certain information so maybe worth a google?? |
28th Dec 2011 11:09pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6733 |
Since the car is BMW ECU based, "adjusting" the mileage isn't too difficult and may have been done by a unscrupulous previous owner.
28th Dec 2011 11:19pm |
Yep. http://www.direct.gov.uk/en/Motoring/Ownin...G_10020539 Graham ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
28th Dec 2011 11:20pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
If you know where to go and who to see you can have your mileage "corrected" or altered to you and i for as little as £100 upwards and takes around 20mins!
29th Dec 2011 8:44am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1703 |
Well I have a black dot next to my mileage.
29th Dec 2011 9:07am |
