Home > Maintenance & Mods (L322) > Need new rear lights. Will these fr Ebay work?
starman
Sweden 2005 Range Rover Vogue 4.4 V8 Giverny Green
I have a 05 Vogue.
I should have known better. I should have remembered that i´m not a DIY guy.
But last night after a few glass of red wine, i seemed to have forgotten...
I decided to try to mount the guards for the rear lights. Bad idea.
Was not gentle enough when i removed the first, the drivers side (in my country). left side.
My english is not good enough to be able to explain what happened. But the two pieces on the lamp itself w the"holes" were the two screws go, got broken.
So now i need to get my self a new rear light. Those are impossible to find used over here, and new are very expensive.
I´m thinking i might as well get the S/C or the clear/red ones. I think the S/C look pretty good.
I have no intention in trying to make my RR look like a S/C. I just choose what looks best.
Pls look at this guys two ads on ebay. They should work, just plug´n play right?
But this time i will have to let a shop do it for me.
It saids they are genuine. So i assume that is correct. Can you tell?
Which would you think would look best on a Giverny green?
http://www.ebay.co.uk/itm/RANGE-ROVER-SUPE...982wt_1144
http://www.ebay.co.uk/itm/RANGE-ROVER-VOGU...000wt_1144
Post #99605 28th Dec 2011 9:27pm
second ones mate.. ... - .- -.
Post #99607 28th Dec 2011 9:39pm
Why not try and glue the bits of plastic where the two screws go into using Superglue and then be gentle when you refit the screws.
Post #99610 28th Dec 2011 9:41pm
starman
scarey wrote:
second ones mate..
The red and clear?
Can you tell if they are genuine? And if so they are plug ´n play?
Post #99611 28th Dec 2011 9:42pm
starman
You might be right. Might not be a bad idea at all. I will look in to that. Thanks a lot.
But BEFORE i do any more things on my car. Is there anything that could go wrong when i pull out that wire????
Post #99612 28th Dec 2011 9:43pm
they will be genuine afaik no one makes aftermarket ones..
they are plug and play.. ... - .- -.
Post #99613 28th Dec 2011 9:43pm
starman
Thanks scary. Always fast replies. (and now i´m happy that you don´t reply - "wiki" Very Happy
All the best
Post #99615 28th Dec 2011 9:47pm
Laughing Thumbs Up ... - .- -.
Post #99616 28th Dec 2011 9:53pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I got some of the ones from the first link & they are genuine & easy to fit, work very well & a lot brighter than my old orange & red ones! Range Rover 4.4 V8 Vogue
Post #99752 29th Dec 2011 9:48pm
