Home > Maintenance & Mods (L322) > DSC, Transmission, Low range, HDC etc. Inactive, Susp low |
Sounds Battery related so a RESET may be in order. I think you disconnect battery teminals and briefly touch them together but you better check with other answers first. |
23rd Dec 2011 8:15am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3142 |
check your battery conections (especially neg pole) and/or your ABS module connections. all these lights coming on point to the ABS module not being able to read the inputs from all the different sensors and so brings up a fault for each of them
23rd Dec 2011 9:31am |
Hi guys, thanks for the quick feedback. Will do the battery trick like Gaz suggested.
23rd Dec 2011 9:46am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I wouldn't recomend using WD40 to clean electrical connectors as it is oil and can act as an insualtor if not cleaned off properly 56 TDV8 Vogue SE
23rd Dec 2011 11:51am |
Hi Andy, totally agree, unfortunately it is the only stuff I have here right now. Not easy finding anything here. I would love to get my hands on some decent contact cleaner !!
23rd Dec 2011 3:46pm |
