Home > Maintenance & Mods (L322) > Just won on ebay
Kads
Just won on ebay
Hi all,
Just won a set of L322 brembo calipers and pads.
What other items do i require to upgrade my front brakes.
What discs?
What brake lines?
etc?
many thanks Kads
Post #98915 22nd Dec 2011 4:49pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I might be wrong, but I think you have to have the right size wheels as well
Post #98917 22nd Dec 2011 4:51pm
Kads
sorry got 22 inch overfinch on mine, so thats not an issue. Kads
Post #98919 22nd Dec 2011 4:51pm
daveo
hi was it the chap that had 2 sets with buy now Shocked new with pads but scratched fron being stored...... V8 facelift Range Rover Autobiography 22" wheels.
Post #98920 22nd Dec 2011 4:52pm
Kads
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...CA:GB:1123
link attached
he didnt have much of a description? but it did state L322 Kads
Post #98924 22nd Dec 2011 4:58pm
daveo
hi not the ones i was thinking of, you will need the 344mm disc, i think thats the size but they will or should be listed as for brembo's as they are bigger then standard, if you go for new disc then you must put a new set of pads. the pads come up on ebay some times for around £40 and the sensor around a tenner. you will need new flexi brake pipes as well. now for the hard bit.
you will need to cut the backing plate/splash shield so it will clear the caliper.
http://www.ebay.co.uk/itm/SFP500070-RANGE-...396wt_1112
http://www.ebay.co.uk/itm/RANGE-ROVER-3-0T...397wt_1112
http://www.ebay.co.uk/itm/SDB500193-RANGE-...376wt_1112
http://www.ebay.co.uk/itm/SEM500090-RANGE-...394wt_1112 V8 facelift Range Rover Autobiography 22" wheels.
Post #98927 22nd Dec 2011 5:07pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Hi Daveo, I was going to buy those exact callipers (scratched brembos) tomorrow as my current std calliper is sticking on. Tell me what you know, especially if its bad!!
Stevey
Post #163127 9th Jan 2013 8:05pm
daveo
if they are the same ones i was looking at then they wont fit, they were for a sport. pm me the link and i will look, it down to the mounting bracket on the back, on the l322 thay are at 45 degees and on the sport they are straight up. V8 facelift Range Rover Autobiography 22" wheels.
Post #163165 9th Jan 2013 9:02pm
SteveyD
Ah ok, the listing states they are for L322 only and will not fit disco or RRS. The item has ended now but seller still has stock (spoke to him last week) it's eBay no eBay Item No. 140861654700 if you get a min.
Listing also says as fitted to tdv8, bolts straight on without issues to a 14 cm hole pattern but then mentions to do your own research.
Post #163219 9th Jan 2013 10:27pm
daveo
hmmmm,they are not the set i was looking at, i am not sure, the gloss black were the first type and were fitted to the early super charged, the grey mat ones were fitted to the tdv8 but i thin they had different front legs, what year is your car.. V8 facelift Range Rover Autobiography 22" wheels.
Post #163240 9th Jan 2013 11:56pm
SteveyD
My cars 2003 TD6, I might get it on the ramps and remove/measure the caliper tomorrow. I'd planned on a brake upgrade ASAP anyway as I couldn't believe the lack of stopping power my car has, so these calipers seemed a good buy. Matching discs seem cheap enough too.
I'm guessing they were not the ones you spotted then? Ill bell the guy tomorrow and see if he can shed any light.
Cheers
Steve
Post #163242 10th Jan 2013 12:13am
daveo
here is a pic of the back of my caliper
the mounting arms are the same as my ones so they might fit,
he does say they are for the l322
but you will need a few items for them to fit, disc,hoses,sensors and the backing plates...but the stopping power is far far better.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #163244 10th Jan 2013 1:08am
Maybe I'm wrong but an LR tech told me the sport ones would fit an l322 as the bolt dimensions were the same... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #163271 10th Jan 2013 9:18am
NO KP 100% wrong my friend... They dont fit from D3/Sport onto L322... Thumbs Up
Post #163276 10th Jan 2013 9:24am
Best speak to the dealer tech again as he said the pattern was the same... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #163283 10th Jan 2013 9:47am
