Home > In Car Electronics (L322) > No sound |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Undo the two 8mm bolts at the top and it should just slide up and out... Check the big black plug on the top, that's the normal one that suffers with water...
20th Dec 2011 8:28pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
Thanks for that.
20th Dec 2011 8:46pm |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
Not sure what year yours is but mine is a 2005 and a nicedayforit is ceratinly what you will need. I just changed my TV Tuner and the amp is on the same plate, and it is actually bolted in from behind with four star bolts which you can not get to, it was a bitch of a job but the following might help whihc was one of the guys put on a post for me. if you go to the lnk it has step by step guide of what needs to come out to get that out and its a few bolts etc. Took me about two hours from start to finish
21st Dec 2011 11:26pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Before you get stuck in, worth checking the Radio fuse (no 8, a 5amp, at the front on my '02). I blew mine by accident and it knocked out all sound and the radio itself! .
22nd Dec 2011 12:00am |
Definitely not the radio fuse, radio is working, just no sound.
27th Dec 2011 12:28pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Lol.. Just came in to do a search as I am having the same problem myself.. Its Stuck on the land rover sign on the display, red light flashing off/on. Found water on the top Nokia module, so I assume there is water on other components.
27th Dec 2011 1:27pm |
Just taken out the frame with Nokia, dvdrom and DVD changer, cheers renegade2 for link. Connectors are all looking fine and clean. I picked up the unit to put it back in and noticed a small puddle. Full of bloody water.
27th Dec 2011 2:09pm |
volores Member Since: 03 Nov 2011 Location: Melton Mowbray Posts: 55 |
Mine has lost all sound this morning (!!!!??) - was fine last night - had the radio and CD on - get in this morning - nothing......all working fine on the screen, cd counter going up so its playing.....just no sound....almost like someone has flicked the mute button!
29th Dec 2011 8:39am |
Try taking each of the plug connectors off the amplifier and spraying the plugs and sockets with a liberal dose of electrical contact cleaner.
3rd Jan 2012 1:36pm |
Spoke too soon, sound has gone off again
4th Jan 2012 12:17pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Niceday, can you post a picture of your amp. I may have a replacement. Need to see what connections you have. I had 3 broken pins caused by corrosion and had to replace the amp. Took it all apart first to try adn fix but the connector units are not able to be removed AFAIK. in any case would involve a new pin and re-solder with very little space to work in. |
4th Jan 2012 3:34pm |
@Dolphinboy
4th Jan 2012 4:56pm |
I had this a while back and all I needed to do was a hard reset but disconnecting battery touching leads together and putting back together. He Presto sound restored......(Common fault)
4th Jan 2012 5:14pm |
Unfortunately there is a pin broken off in the socket on the amp which happens to be a used, it seems to serve a communication link cable. All the bits are working ok just no sound, if I wiggle the plug I get noise from the speakers.
4th Jan 2012 5:40pm |
