Home > Technical (L322) > failing to charge under load... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 393 |
Hi,
18th Dec 2011 6:42pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Well, if it is definitely diagnosed as not charging at higher revs (under load) then one does need to look at what the alternator is up to.
18th Dec 2011 8:18pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Could be a failed regulator on the alternator or worn brushes. As others have stated you need to get the alternator and battery tested 56 TDV8 Vogue SE
18th Dec 2011 11:09pm |
I was speaking to an auto-electrician who specialises in alternators and he says the TD6 alternators are not known for faults |
18th Dec 2011 11:31pm |
On both occassions that LR Assist came out they checked the battery and said it was fine. It went through their conditioning checks with no issues.
19th Dec 2011 1:19pm |
Famous last words . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
19th Dec 2011 2:18pm |
20th Dec 2011 9:10am |
Ex BMW worker, bound to be bias and tell lies about FFRRs |
20th Dec 2011 9:35am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
The battery on my TDV8 was discharged a couple of times over the last few months and each time the technician said it was charging ok and was in good order.
21st Dec 2011 1:09pm |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
Ihad the same problem with my TD6 2005 vOGUE, i had it suddenly dischargeD during a day and LR Assist came out started it , tested it and said all was ok, took it into the dealer who could not find anything wrong and no baTtery drain. This happend a few times so about six months ago had dealer fit a brand new battery. However i have noticed recently that the HDC Inactive light comes on first thing in the morning but goes off once started a few seconds. AlSO i notIced that the touchscreen comes on then goes of when the engine is turned over thus taking afew seconds to come back. Everyone is telling me I need a new battery but I can not accept this after six months. Dealer says there is no drain, but the AA says that somethiung is drawing power.
21st Dec 2011 11:14pm |
Well I had the battery checked by a mate who's an auto electrician. His suggestion was to get a new battery first off and recommended this one -
22nd Dec 2011 6:59pm |
Ok - Battery changed and clamp installed (£3.49) from Halfords to secure it in place. No problems since (looked under the removed battery... stamped 10/05 so it was the original one.
27th Dec 2011 9:33pm |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 |
I know it's a bit after the fact, but I had this problem on our 4.4 6 weeks ago. AA said the alternator was not charging under load. Guy salmon found that the battery terminal was loose.... Problem solved, and no charge from guy salmon ('scuse the pun!) |
30th Dec 2011 7:31pm |
31st Dec 2011 12:30am |
