Home > Technical (L322) > My FBH is switching itself on... |
Already dunit
16th Dec 2011 8:13am |
It will be johnte.
16th Dec 2011 9:33am |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
I've also just read on another thread that the 'tapping' noise that I can hear round the spare wheel well area, could be the FBH fuel pump. This makes sense. As when I leave the car running to look for the noise, by the time I get everything out of the boot + spare wheel + jack- The tapping stops....
16th Dec 2011 9:40am |
Exactly.
16th Dec 2011 1:37pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
MY11 FBH = auxiliary heater?
16th Dec 2011 5:50pm |
Steve
16th Dec 2011 6:10pm |
Hi Rambles,
16th Dec 2011 10:53pm |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
Steve wonder if you might have any thoughts on my probelm / question.?
16th Dec 2011 11:24pm |
As I mentioned in the FBH thread in the technical section, my experience is actually with heaters a gen older than these, but if I were to venture a guess, I'd say either the heater is not igniting (and you are only hearing the combustion air blower - this shuts off after a bit though) or the water pump is not up to snuff (although this should cause a heater to overheat and shut down. Or the heat is actually getting inside the car but the blowers /flaps aren't letting it out.
16th Dec 2011 11:45pm |
Steve
17th Dec 2011 7:41am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2575 |
Experienced the same on a 2008 TDV8 - once you'd parked up (didn't seem to be any pattern to it regarding length of journey), you could sometimes hear the heater running and see the exhaust venting from the N/S front wheel arch. It only seemed to happen when the outside temperature was fairly low, the remote fob was never touched (in fact, it wasn't even on the key ring).
17th Dec 2011 12:01pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 |
Update...
20th Dec 2011 8:17pm |
the FBH should come on as soon as the door is unlocked / opened? and your dealer told you that was normal?
21st Dec 2011 7:15am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Here's an idea...
21st Dec 2011 8:56am |
