Home > Technical (L322) > My FBH is switching itself on... |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
I'll swap. Mine won't switch on. But no ideas, sorry... Graham
15th Dec 2011 10:14pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 |
Thanks haha sounds a plan.
15th Dec 2011 10:35pm |
Sounds like the car isn't fully going to sleep.
15th Dec 2011 10:44pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Sorry no idea why, but mine has started doing the same I don't have a remote, but mine turns itself off again after somewhere between 2 and 5 minutes. Doesn't do it every time, but seems to be random.. Hopefully someone will come up with an answer |
15th Dec 2011 10:45pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
might sound silly but try taking the batt out of the remote.. it could be faulty and is sending the signal to switch on... its te first thing i would do.. V8 facelift Range Rover Autobiography 22" wheels.
15th Dec 2011 10:47pm |
How do you manage to switch yours off? If I go into the car when its switched itself back on, on the touch screen 'Manual Heat' is illuminated when its on and all timers are 'Off.' Really confused. |
15th Dec 2011 10:48pm |
How about swapping them over then getting "mine" fixed on "your" warranty...
15th Dec 2011 11:21pm |
is your engine upto temprature at this point and do you lock the car when you leave it? |
15th Dec 2011 11:37pm |
Yes up to temperature, FBH comes on once I've locked the car and come back about 2 minutes later to find it chucking out so much hot air! |
15th Dec 2011 11:50pm |
Have you not asked the dealer to take a look? That's what I'd be doing if mine was a 2011 |
16th Dec 2011 12:00am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
This is happening because:
16th Dec 2011 6:32am |
Makes sense. What a joke. I have taken the batteries out the FBH remote and 10 minutes later it switched itself back on. No Low Battery warning though so far. |
16th Dec 2011 7:10am |
Rambles, you are sure of this? Confirmed by whom? This would def be an error in the programming of the FBH/ATC ECU. The reason I ask is that, after several years of playing with and researching FBHs, this is the very first time I have ever read this. And even many of the technicians at main dealers don't know poop about the FBH and tend to speak out of their @&%es just to get customers off their lots. Rumors and BS fly heavy and thick on this topic. (see 'Have I gaot a FBH' in the general section).
16th Dec 2011 7:18am |
Steve, you seem to be an expert on this unit, any idea where I could get mine repaired? Graham
16th Dec 2011 7:32am |
