Home > Technical (L322) > My wheels are worn!
RANGEROVER
England 2003 Range Rover SE Td6 Zambezi Silver
My wheels are worn!
Had a puncture the other morning, put the spare on threw the punctured tyre in the boot. Knew that it really wanted replacing as it was pretty worn along the edge, also I knew the other side was down to the indicators aswell. Took it in to have a couple of tyre fitted, left one wheel/tyre and went to work, phone rings, "we have a problem, your wheel is worn", I laugh thinking it was some kind of joke, but no my wheel has really worn! They wont take the other tyre off incase the wheel is the same and wont fit tyres to the wheels because of the obvious saftey issue.
Has anyone had this problem??
The tyre fitters say this is a common problem??
I will try to attach a picture if I can brave going outside again.....to see what people think
The wheels are genuine Land Rover 18".
Now trying to source a wheel or set! Running with no spare for 4 days now and think I pushing my luck!
Post #97560 13th Dec 2011 7:13pm
http://www.fullfatrr.com/forum/topic8905.html ====================================
Post #97563 13th Dec 2011 7:17pm
Never ever heard that before!
Heard and seen buckled, cracked and dented rims but that's it!
How the heck is it worn!!
Get on the phone to Dan if you can stretch your cash am get new wheels and tyres if needs must or a cheapy used set from the bay or members from here Smile
Post #97564 13th Dec 2011 7:18pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I have an 18" wheel for sale. It used to be my spare before I bought a full new set. It's the Five spoke type and virtually brand new, fitted with a Goodyear Wrangker HP was has only been used for a few miles (still got all the pimples on the tyre). I will post a picture if you are interested. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #97569 13th Dec 2011 7:22pm
RANGEROVER
Pictures of said wheel
Above is the inside edge below is the out side
Thanks Mick for the link might be interested in those, I might have a set coming up from a customer of mine who is only 20miles away. Thumbs Up
Thanks Mickeyjd again might be interested just trying to find something local first. Thumbs Up
Not sure what the other wheels are like until I get another tyre pulled, they might all be like it!
It's really thin on the inside edge!
I wonder what caused it? My last tyres were cheapo Nexan tyres but I can't believe that would be the cause.
Post #97584 13th Dec 2011 8:03pm
Looks like it's been run on a puncture
Post #97585 13th Dec 2011 8:05pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
As above - 47p2 beat me to it Wink
Post #97590 13th Dec 2011 8:31pm
RANGEROVER
The wear is rippled but not rough, it does not look like it's been running on the road itself...
The outside edge is OK except were I photographed. So that edge show very little signs of Damage/wear.
The edge were the beading goes is slightly rough/sharp but that is lower than the edge itself.
The fitters claim it is wear, and that the Discoverys, Rangies and Mercs suffer it??? (I have never heard it before!)
Obviously there is a chance that it has been run on a puncture within its life at some point...
Post #97595 13th Dec 2011 8:53pm
ebajema
It looks like the tyre changing machine didn't clamp properly and the wheel started "sliding" through the clamp brackets and one of the brackets did this ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #97598 13th Dec 2011 9:09pm
ric355
I doubt that - the marks would seem to be in the wrong direction for that to happen, and furthermore the tyre machine usually has plastic jaw covers on it to stop the alloy from being marked. I'd go with the running on a flat tyre conclusion.
Post #97607 13th Dec 2011 10:32pm
ric355
Interestingly the worn area is not flat it is curved, so on reflection that would indeed suggest something other than running on the road surface.
Post #97612 13th Dec 2011 10:38pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Loos like it has seem some heat !! I'd say it ran a fair distance with a puncture Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #97615 13th Dec 2011 10:45pm
The punctured tyre-wall would have been against the rim, therefore the marks as you see
Post #97622 13th Dec 2011 11:56pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
To busy looking at the lovely fire in the background to notic the wheel Whistle
Post #97625 14th Dec 2011 6:21am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
"the tyre fitter said it was a known problem" - yes the pimple faced 15 year old part time apprentice really should stop giving personal opinions to customers.......
+1 for the fire
Post #97628 14th Dec 2011 7:15am
