Home > General > Buying a Vogue around 05 year |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 224 |
Not sure of all the changes between the pre-2005 to 2005 onward cars but to name a few:
10th Dec 2011 1:10pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Facelift was engine, gearbox, and many other areas, such as different EAS compressor pump, improved sound insulation, touch screen navigation...
10th Dec 2011 1:37pm |
I completely forgot about the new Gearbox, and more obviously the revised bodywork, which I have to admit is one of the best looking FFRR styles to this day. |
10th Dec 2011 2:32pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Face lift models with TD6 engines still have the GM gearbox, which I would avoid.
10th Dec 2011 4:14pm |
Kensta Member Since: 08 Dec 2011 Location: North east Posts: 17 |
Cheers guys! Is the td6 gearbox a common issue? Petrol engine is something to think about! I had a BMW X5 petrol and got it lpg'd and it was great, Do the rangerover engines handle the LPG conversion ok? Dont they overheat or sum thing? Sensors and electrics seem to be an issue on all range rovers don't they! We get the same faults on the sports but fingers crossed mines been fine Rangey Sport OverFinch owner from the otherside |
10th Dec 2011 5:57pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
I was determined to get the 06 MY facelift model when I was looking for mine. I too looked at all TD6, 4.4 (Jag) & TDV8 models. I ended up with a very good TD6 Vogue.
10th Dec 2011 6:28pm |
TugRR wot year is yors m8? How long u had it? Rangey Sport OverFinch owner from the otherside |
10th Dec 2011 6:34pm |
Like tug i got a pre facelift TD6, mine has much higher miles on it though (124k when bought, 131k now) and still going ok. I got mine knowning i would struggle to get a warranty for it due to milage which is a bit of a shame really as it seems to be solid enough at the minute (runs and touchs lots of wood and tries to find a 4 leafed clover!)
10th Dec 2011 7:35pm |
Good summary KP.
10th Dec 2011 7:48pm |
Just to clarify, Kingpleb, my car and I believe yours is what I'd refer to as the facelift model. ie smaller headlights and "kinked" front bumper. The VIN gives it away - it has 06A in it. I've seen late '54 and early '05 registered cars for sale advertised as "facelift" cars as they had the touchscreen audio/satnav.
10th Dec 2011 8:29pm |
TugRR, i class mine as pre facelift as its got the mix and match bits n bobs but the full facelift is the TDV8 or MY06 onward where the interior is changed as well so a true facelift
10th Dec 2011 8:54pm |
Cheers for all the help lads! How much ru looking at to get the Td6 gearbox repaired or repplaced with a recon if it does go? Is that the only major issue with the Vogue? Suppose if it got a decent warranty I wud have that covered anyway, I've got AA warranty on my sport at the mo and got a new battery fitted off them last month with no quibbles. Do the TD6 Vogues respond well to power chips and remaps for the mpg? Rangey Sport OverFinch owner from the otherside |
11th Dec 2011 8:11am |
Just thinking is the td6 gearbox made by BMW? I remember the older X5 gearboxes were prone to knacken up too! Rangey Sport OverFinch owner from the otherside |
11th Dec 2011 8:31am |
Probably £2k for a rebuild. A warranty could possibly claim a failed gearbox was wear and tear. Have you driven the TD6? Drive it as much as you can, you may like it, personally I really didn't. I found it just underpowered, and revs too high at motorway speeds, apparently they respond well to remaps, so see if you can try one which has been remapped.
11th Dec 2011 8:48am |
