![]() | Home > Maintenance & Mods (L322) > Fitting new battery ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
masses of info on this , use the search function, but put the bonnet into service mode and get a stool to stand on.
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
hi mate, if you check on youtube, you will find a video from powerflow uk or something and they should you how to put it in service mode.
I had no problem getting a new 110AH battery in without setting the bonnet in service mode, just dropped straight in first go.
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 ![]() ![]() ![]() |
Dont forget to wait ten minutes after turning off the engine before changing Battery. |
.........and once the battery is fitted turn the steering wheel fully left then full right to set the steering parameters.. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
This is the youtube link RR8701 was referring to:
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
Does anyone know if you have to re-enter the head-unit code?
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 ![]() ![]() ![]() |
I didn't need to reenter any codes on an '04. Some more info here |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 742 ![]() ![]() |
Thanks for all the info |
I bought that very one a month ago,the best thing i have ever done. |
thats the best one john... |
All fitted now - it's never spun over so fast |
I thought you had to follow this proceedure to disconnect and reconnect the battery because of the pyrotechnic device in the battery +ve cable.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
A friend of mine once had a Seat Leon Cupra R which did the same thing, I think it was either an aux coolant or oil pump, something to do with the turbo IIRC, might be the same on the FFRR? 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
