Home > Maintenance & Mods (L322) > Picture Request - Rear Armature Mounts / Bumper Brackets
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Does anyone have any pictures of the rear of the car with the bumper mounting removed - i.e. the areas where the towbar armature would bolt onto ?
I am trying to determine if these mounting areas are the source of my water ingress to the boot.
I know that when you buy the armature you get two gaskets to go between the armature and the body but was wondering what size of hole is in the body or if its just the bolt holes ?
Any pictures would help !
Thanks
Colin Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #96457 6th Dec 2011 10:59am
ric355
Assuming your car is the same as the earlier ones in terms of how the thing is mounted, I doubt that is your problem. The reason being that the bolts do not protrude into the boot. They are bolted directly into the chassis where there is a captive nut.
Post #96468 6th Dec 2011 12:37pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Sorry didn't take pictures when I installed my Tow bar but from memory the 06 onwards has long captive bolts which protrude through the bodywork into the boot where the nylock nuts are attached.
Post #96469 6th Dec 2011 12:47pm
Johnte
^^^^ That's correct, had mine off last week. But unfortunately didn't take pics Embarassed
Post #96480 6th Dec 2011 1:51pm
CG-SC
Can you remember if there was a gasket at the body / bracket interface ?? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #96518 6th Dec 2011 7:14pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi Colin,
You can see a diagram showing the gaskets on Topix
http://topix.landrover.jlrext.com
Select "New Range Rover" choose your model year and then select "Owner"
Then Select "Accessory Fitting Instructions", then "Towing: and finally "VUB000740/503960KNI000014/500020 - Towbar kit Armature"
If your lucky the following link will take you there directly
http://topix.landrover.jlrext.com/topix/co...p;id=62886
Gone - Range Rover Supercharged 2006
Post #96521 6th Dec 2011 7:33pm
CG-SC
Thanks Justin - that has helped me, I'm thinking that's where the water is getting in, now deciding whether just to buy an armature, strip the bumper off and seal / fit the armature and be done with it - was going to get one next year anyway for carrying a couple of bikes...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #96531 6th Dec 2011 8:40pm
