Home > Technical (L322) > Front side lights and fogs
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Evening all. Some of you may have seen on the Salisbury Plain event thread that I have a water/mud build up problem in my front side lights and fog lights.
How easy is it to removes these and what do I need to do??
Thanks in advance Thumbs Up FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #96166 4th Dec 2011 8:17pm
dan_uk_1984
Sidelights can be a PITA if the main wing-nut is corroded to Censored as mine was. I ended up snapping the thing. In hindsight if you cant get it out easily - take the whole HL unit out. It's only 3 bolts and is easy peasy. As you've cacked all up the inside you may as well take it all out and get the jet wash in there.
As for your fogs - you lever the bezel off then there are 3 screws holding the lamp housing in place. Once you've got the bezel off it's plain sailing and fairly Starr forward. There isn't much wiring loom to play with that's the only downside, which can make removal/refitting a little tight/fiddly.
Post #96168 4th Dec 2011 8:25pm
GregP
Thanks Dan, glad you're back to help me out. Thumbs Up
Maybe when you're next at Exeter Services I'll pop across and you can do it for me Wink FFRR TD6 HSE
Post #96170 4th Dec 2011 8:30pm
dan_uk_1984
Not a lot I won't do for a Costa!
Post #96171 4th Dec 2011 8:35pm
GregP
lol
If you ever are in the Exmouth area and have time to burn drop me a PM. It would be good to meet, especially once you have a FF again Thumbs Up FFRR TD6 HSE
Post #96175 4th Dec 2011 8:57pm
hi greg, sidelights have 2 large plastic butterfly nuts which unscrew and the units come off, the fogs have surrounds that you prise off using a plastic spatula or similar , then there are 3 screws that hold the light unit in place..
Post #96199 4th Dec 2011 9:57pm
GregP
Cheers Stan. I'll aim to get this sorted asap Thumbs Up FFRR TD6 HSE
Post #96201 4th Dec 2011 10:00pm
Greg, if you need fog lamps replaced let me know pal... I have a box full of good used ones so if you pay the postage and make a donation to the ff site I'll send you down a set or you can collect if your up the M5...
Craig Thumbs Up
Post #96233 4th Dec 2011 11:55pm
GregP
Cheers Craig Thumbs Up
Really appreciate the offer. Hopefully mine just need a good clean but if there is anything more serious wrong with them I'll drop you a pm and arrange it. FFRR TD6 HSE
Post #96234 4th Dec 2011 11:58pm
No worries, if it makes a small donation to this site its worth it to me for a cracking day out on Saturday pal...
Craig Thumbs Up
Post #96240 5th Dec 2011 12:23am
