![]() | Home > Technical (L322) > Knocking/rattling noise coming from front suspension? |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 ![]() ![]() ![]() |
Sounds like anti roll bar drop links to me - less than £30 a side to fix |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I'm in the same position, my front suspension knocks and have done the following-
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
Track rod ends are certainly a possibility - only ever rattled going over bumpy ground, couldn't feel anything untoward through the steering. Simple fix if it is. |
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 ![]() ![]() ![]() |
Gents // I had my drivers side strut changed yesterday ( for other reasons) however today when taking the little one to school I could here a knocking from the front, after checking it out I found that the nut that secures the strut to the upper body part of the car had worked loose |
redferrari Member Since: 04 Dec 2011 Location: UK Posts: 5 ![]() |
Thanks for the input guys. I don't really know what to do. The garage say that nothing needs replacing but obviously they will replace parts if I tell them to but they say its not necessary. It does seem a bit of a mystery!! Are we sure this noise is coming from suspension/steering etc etc and its not something else? The car drives perfect apart from this. Making sure the struts are tightened up is obviously the place to start. |
Forgot to ask if anyone has been to a dealer with this problem? On the basis that if the noise does not stop then they won't get paid!!! |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Not familiar with that engine, but does the exhaust run close to the bodywork anywhere in that area? Maybe a bracket is lose or something. No longer FF owner but still interested. Present car Jaguar XE
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Jack up the side of the car that the noise is coming from. Grab the wheel and try and move it back and forward from top to bottom. If there is any play, it is your transverse link ball joints.
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Did you ever find out what was causing this knock?? I have exactly the same knock on my front suspension on the passenger side. I've spent a fortune trying to get rid of it. It started when I replaced the front passenger side air strut for a new one. Went for a test drive and first heard the knocking. I've replaced both sides upper and lower hub bushes at the rear and the trailing link arms, this didn't work. Then the anti roll bar drop links, no luck with that either. I've checked every bolt on the new strut & had the car on a ramp and it's still knocking, it's driving me mad, literally. I recently had the car MOT'd and they couldn't find any loos or worn bushes. In a last ditch attempt to find the cause I took the car to a Land Rover dealer who charged me £550 and the knocking is still there! So far this has cost me over £1000 and I'm no nearer than when it all started. I've also checked the obvious stuff like battery mounts and pipes & cables (all secure) Has anyone ever cured this annoying knocking? It's fine on a smooth road but as soon as I drive down a country road it knocks constantly.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
inner wheel arch? ... - .- -.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I had a strange knocking noise that drove me round the bend on an X5. It was apparent even when leaving the drive. It turned out to be the steering rack mounts. Although not loose, a 1/4 turn on the mounting bolts cured it.
sidmini Member Since: 20 Sep 2010 Location: kent Posts: 45 ![]() ![]() ![]() |
i'm getting a similar issue, just a thought could it be shock / movement that it working its way up to the wood vaneer vent trims and causing a little knock noise? |
I'm sure it's suspension related, when you jump up & down on the top of the tire it makes a very faint knocking noise. |
