Home > Technical (L322) > Oil top up with castrol magnatec 5W30?
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi Chaps,
Is it ok to top up my engine which was last filled with castrol edge 5W30 with a litre of castrol magnatec 5W30, or should I only top up with the same castrol edge 5W30
Thanks,
Justin
Gone - Range Rover Supercharged 2006
Post #95936 3rd Dec 2011 8:32pm
Did you know there are two specs of magnatec ? Do not use A1. The correct stuff is the A3 B4 spec oil for the TD6. Previously..
Post #96007 4th Dec 2011 12:31am
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Edge is a little over the top if you don't have a DPF fitted.
The Magnatec 5-30 is fine though. They are backward compatible.
Post #96146 4th Dec 2011 8:04pm
