Home > Technical (L322) > Battery discharge |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
Welcome!
It's a reasonably common fault - Use the magical, amazing, totally unbelievable "Search" button on the top of the page^^^^^^^^^ and you'll get some pointers. It's better than Siri - Honest! If you're lucky you'll end up spending the next 5 hours in the time warp that is the forum archive and come out knowing all sorts of amazing things you didn't before about your FF... |
3rd Dec 2011 10:23am |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
Lots of info on here regarding battery discharge. Gain as much in as possible and then speak to your dealer. If your dealer can not find a fault and not prepared to renew your battery, then change your dealer. There are lots in Hampshire.
3rd Dec 2011 12:51pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
I had similar and it needed a software upgrade, as all the electronics were not shutting down correctly.
3rd Dec 2011 1:21pm |
