Home > General > Serious Misting Up
Page 2 of 3 <123>
Yeah its dry ====================================
Post #95513 1st Dec 2011 1:55pm
Might just have been caused by the excessive rainfall we had the past week Mick, then getting in and out with damp clothing won't help.
Post #95517 1st Dec 2011 1:59pm
Have only got in the car in the mornings John to do the school run to the train station , straight out the house into car wouldn't have damp clothing on ….
What i have noticed is that when i put the Auto air con on , on that dial there is no orange marker lights that show , (which did on the SC) up unless i press full A/C (separate button) ….
Maybe the air con is gubbed Confused Confused ====================================
Post #95519 1st Dec 2011 2:06pm
Mick, check the front carpets are not wet (blocked drainage from the front scuttle area)
Post #95530 1st Dec 2011 2:57pm
Googsy
Is sunroof fully closed ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #95541 1st Dec 2011 3:26pm
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
mick
from memory on my 2008, same on my latest 2011, when the aircon is on auto both lights will be illuminated on the temperature/aircon dial.the system will sense the temperature and alter the fan speed automatically until it gets to the desired temperature
when u want just aircon to stay on but manually alter the temperature only one light is on.
i think theres either something wrong with the temperature switch or the aircon is not working properly.
you can even have the temperature dial right up to hottest temperature , which allows hot air to come out of the vents but the aircon/air dryer should still be working.
this is what takes the misting away from inside
hope this helps Thumbs Up
Post #95544 1st Dec 2011 3:38pm
Thumbs Up Ian and others …
This is roughly what i mean ( sorry pish i-phone pics ) .. Took them without the Flash on so you could see what lights i am referring to
Picture 1
When i press just the A/C button on the left hand side the centre Auto button stay's the way it is , yet on the SC a series of lights around the dial would illuminate although there is a rush of air through all the vents ….
Picture 2
When i press the top left button for MAX A/C that is when the centre dial illuminates and although there is plenty of air coming through the vents , so i am guessing that the Air Con works okay , and have checked everywhere inside the car , top of footwells , floor , boot area , door seals , drain runners , not one bit of dampness or water anywhere inside the car , just cannot figure out where all the heavy misting is coming from …
Post #95611 1st Dec 2011 6:43pm
you havnt got the air recirculation switch on have you mick..
Post #95619 1st Dec 2011 7:14pm
That's the third switch down from the top that is lit on the left hand side .. Thumbs Up ====================================
Post #95620 1st Dec 2011 7:19pm
if you have that on then you dont get fresh air from the outside....the same air inside the range will cause misting [i think]
Post #95621 1st Dec 2011 7:23pm
I have tried both either re circulating or the other …. just friggin weird really Thumbs Up ====================================
Post #95635 1st Dec 2011 8:05pm
must be kinda frustrating as you've paid all that dough for it...
Post #95637 1st Dec 2011 8:08pm
Such is life stan , such is life …. Laughing Laughing ====================================
Post #95639 1st Dec 2011 8:12pm
just noticed, congats on your 6k... Thumbs Up
Post #95640 1st Dec 2011 8:15pm
Just set the temp, Press the Auto button in the middle, and the auto re-circulating button and jobs done!
Post #95641 1st Dec 2011 8:17pm
Page 2 of 3 <123>
