Home > General > Serious Misting Up
Page 1 of 3 123>
Serious Misting Up
Since now we have started coming into the cold morning's , over the last couple of days when i have went out to start the car , internally the side windows and windscreen have a helluva lot of misting , and i have always kept the Air-Con on @ Automatic since getting the car .
Never had this misting up with the SC ….. plus it can take a good 5 / 7 mins driving before it's fully clear Rolling Eyes
Confused Confused ====================================
Post #95446 1st Dec 2011 10:33am
HAve you checked the spare tyre area for water ingress?
Post #95452 1st Dec 2011 10:56am
Checked your boot and other areas are damp free mick??
Also check door drain holes are clear and your footwells too Smile
Post #95453 1st Dec 2011 10:58am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Might be worth giving the windows a clean with either glass cutting cleaner and isopropyl Alcohol to make sure it's totally clean.
Have you checked the boot for signs of water?
Failing that, could it be anything to do with only having the single level glass- less thermal insulation= more condensation? Though this would again lead back to a source of moisture inside the car.
5-7 mins?? Have you come out and found any cyclists in your grill yet? Thumbs Up Laughing
Post #95454 1st Dec 2011 10:58am
Will check the boot area and such ... Thumbs Up
@Happy Laughing Laughing Laughing mostly squinting like a chinky when peering out through the windscreen … Whistle ====================================
Post #95457 1st Dec 2011 11:16am
Googsy
Cut down on the dogging Mick ......... Sheep
I have that car scene in my head from the Titantic now Whistle
 Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #95458 1st Dec 2011 11:19am
Have checked the boot area … Bone dry .
All footwells also Bone dry …….
Cubby holes in each side in the boot also Bone dry …
Drain channels seem to be clear …..
As happy says maybe try that cleaner stuff on the inside …. Whistle
PS .. Posted wrongly before in another thread it does have Double (glazing) Laminated glass Embarassed ====================================
Post #95462 1st Dec 2011 11:33am
Stephen.125
Thumbs Up Nice one MICK!
Post #95464 1st Dec 2011 12:00pm
M44K TS
My honda and maserati used to steam up, the pollen filter housing on both were clogged with damp leaves, Problem solved after clearing them out, might be worth checking something like that? 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #95479 1st Dec 2011 12:46pm
see what its like with the a/c off for a while....
Post #95489 1st Dec 2011 1:08pm
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
+1 for Pollen Filter
Post #95502 1st Dec 2011 1:35pm
Try not breathing for the first 5/7 minutes of driving Thumbs Up
Post #95507 1st Dec 2011 1:51pm
This is what it looks like , so what do you reckon a new one …… Whistle if you click on it twice it will give you a better idea
Post #95508 1st Dec 2011 1:52pm
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
don't look that dirty
are you sure the aircon is working properly
Post #95510 1st Dec 2011 1:55pm
Doesn't look too bad, is it dry?
Post #95511 1st Dec 2011 1:55pm
Page 1 of 3 123>
