Home > Technical (L322) > Bolts on 22" |
rory Member Since: 30 Dec 2009 Location: Berkshire Posts: 41 |
I have the same bolts for my 19's and 22's.
28th Nov 2011 11:01pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
They differ per manufacturer... Some use OE wheel nuts some use 19mm aftermarket wheel nuts, if they are new wheels they should be supplied with them if they are needed...
28th Nov 2011 11:12pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
cheers boys.........
28th Nov 2011 11:50pm |
22" stormers depending on the factory who made them can use 19mm old or new type OE bolts unfortunately...
28th Nov 2011 11:56pm |
No problems Craig, much appreciated.
29th Nov 2011 12:04pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Measure the diameter of the bolt holes. Also check if the holes are same diameter all the way through. Some non original wheels have tapered holes which need special bolts. No longer FF owner but still interested. Present car Jaguar XE
29th Nov 2011 5:57pm |
I'm lead to believe the original bolts were used on the guys car I am taking them from.
30th Nov 2011 10:42am |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
i have had this problem and found my original bolts where 19mm dia and the hole in my new stormers where 22.5mm so i had to get new bolts also had to check if flat face or taper face inside the wheel nut aperture |
30th Nov 2011 9:27pm |
