Home > Maintenance & Mods (L322) > Brake howl
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Brake howl
My 5 month old FF has had an intermitent brake howl from new, not the usual squeel, the noise made when you blow across the top of a bottle, but on an industrial scale.
It went in on Friday and they have schamfered the pads.
This may be the cure on a 5 year old Skoda from dodgy Dave but is it realy acceptable on a £70k car.
Oh they also "valetted" it and it now reaks of a cheap whores aftershave.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  letters not necessarily in the right order
Post #94717 27th Nov 2011 1:08pm
You must have really dodgy whores down there if they wear "aftershave"!!! I hope you meant perfume.... The song Lola springs to mind.. Rolling with laughter Previously..
Post #94736 27th Nov 2011 4:23pm
On a serious note... It looks like you have 40% less brake pad than you should have. They will wear out faster, overheat quicker and not stop you as quickly as a full face pad.. Not a good fix I would say. Previously..
Post #94785 27th Nov 2011 7:35pm
^^^^ I agree.
Whilst chamfering the leading edges of pads can reduce brake squeel, I have never seen then done to that extent. I would definitely be concerned.
Post #94792 27th Nov 2011 7:54pm
Looks all too clean and shiny to me (just jealous Wink)
I presume this mod didn't cost you anything? If it did, I would go back and ask for some new pads on safety grounds.
A chamfer would only need to be @ 1/4" off the leading edge as a proof of concept.
Anyway, you didn't say if it fixed the problem, or if you felt your braking efficiency improved or declined? .
Post #94821 27th Nov 2011 11:36pm
Dixy
Today having done 7500 miles from new the car anounced worn brake pads. Not impressed. I suppose next they will tell me they are wearing parts and not covered by the warrenty. letters not necessarily in the right order
Post #96182 4th Dec 2011 9:11pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I've seen a service bulletin on the Topix website for this complaint - the bulletins states that the pads need to be replaced with the revised part number to cure the noise issue.
Sorry that I don't have a copy - I read it the other night when I was looking on the site for some info.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #96219 4th Dec 2011 10:24pm
Dixy
Thanks, the car is booked in for tomorow morning, they think a wire may have come off, crettins. letters not necessarily in the right order
Post #96312 5th Dec 2011 2:07pm
