Home > Technical (L322) > Heated Front Screen - How effective? |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 |
How effective is the heated front screen (HFS)?
25th Nov 2011 2:13pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1496 |
+1 Mine had a band about 4" wide right in the centre of the drivers FOV so they swapped the screen under warranty and it's now perfect and will melt ice reasonably quickly.
25th Nov 2011 2:51pm |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 |
As above, the few times i have used mine it seems to clear a misted screen within a minute or two. |
25th Nov 2011 2:53pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
very effective for mist on the inside, ice and snow on the outside... |
25th Nov 2011 4:09pm |
volores Member Since: 04 Nov 2011 Location: Melton Mowbray Posts: 55 |
Hi - sorry to hijack the thread op but I have same concern with mine - it does clear but not that quick and it is vertical bands - is this normal or should it not be in bands? |
26th Nov 2011 6:08pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Never have any mist as Air Con is always on Seriously, use the air con to remove condensation from the car, you won't get anything on the insides in the morning.
26th Nov 2011 8:13pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Just remember - A/C only works above 4 degrees ext. temp. |
27th Nov 2011 12:13pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2937 |
Only one side on mine works. I'm told it may be a fuse. Are there two fuses then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
27th Nov 2011 7:58pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
AC does work below 4 degrees, you just won't notice any cooling effect. The act of the AC at this temp range is to remove moisture from the air coming into the cabin which helps demist the screens etc |
27th Nov 2011 9:18pm |
@simon1233 .
27th Nov 2011 10:36pm |
Noddy,
28th Nov 2011 11:11am |
How effective is the heated front screen?
2nd Dec 2011 9:31am |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
used mine for the first time this winter today
2nd Dec 2011 9:35am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Just remember to not use your wiper blades until clear guys!
2nd Dec 2011 10:15am |
