![]() | Home > General > Gearboxes - 8 and 9spd autos ... |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
This was one of the things I commented on when I drove a new 4.4TDV8 recently.
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Gets into 8th gear by 40mph easy.
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
I thought mine only had 1 gear it's so smooth |
MPH per 1000 rpm in 8th = 48.57
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
It runs through the gears 1,2,3,4 etc. when pulling away from a standing start it will very quickly get through the first 4 gears and then settle to a point where 5,6,7&8 are not noticeable when changing. It it effortless, cruising at 90mph at less than 2000rpm...it's not even awake. Use the flappy paddles across the rev range and you into a whole new driving experience and that's when you need the Brembo brakes!!! |
1853rpm to be precise. |
Even better ![]() Gone: 1 x L405 and 2 x L322's |
And thats why its that much more economical i guess |
