Home > Technical (L322) > RR levelling valve fault & rear pads
blench99
United Kingdom 2005 Range Rover Vogue Td6 Java Black
i have recently changed the NSF levelling valve on RR 05 and when i took it to get calibrated the guy said it was'nt getting correct voltage? when vechile is started it comes up as suspension fault but then levells out and goes off ,any ideas? Also just changed rear pads and warning light still on and check brake pad message, does the codes for this have to be reset ? Many thanks
Post #93581 21st Nov 2011 3:49pm
If the brake pad sensor has previously caused the dash light to come on then a new sensor has to be fitted with the new pads.
The level sensors need calibrated, if the reading is not correct the fault will need to be traced, are you sure the electrical plug is pushed in home
Post #93584 21st Nov 2011 4:01pm
blench99
1 of the tabs on the plug snapped off but i've put a cable tie around it and its def connected ok.
Post #93594 21st Nov 2011 4:35pm
