Home > Maintenance & Mods (L322) > Light Guards - Yes or No?
Lights Guards?
Yes
14%
 14%  [6]
No
80%
 80%  [34]
Not Sure
4%
 4%  [2]
Total Votes: 42
Fitting light guards to your FFRR? .
Post #93075 17th Nov 2011 11:27pm
Yuk! nonononononononononononononononononononononononononononono!
Craig Thumbs Up
Post #93076 17th Nov 2011 11:28pm
That's a no then Craig? Very Happy .
Post #93082 18th Nov 2011 12:12am
T24RES
Not unless you really had to. (e.g- your life depended on it)
Post #93083 18th Nov 2011 12:22am
rich
England 2004 Range Rover Vogue Td6 Epsom Green
Embarassed
Post #93085 18th Nov 2011 1:46am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I personally think they look terrible.......each to their own though ! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #93101 18th Nov 2011 9:15am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Worse when they are aftermarket chrome ones! Shocked
Post #93105 18th Nov 2011 10:35am
fisha
they dont really protect against anything in reality ... if you hit something that will brussh off the guard, the light itself would have been able to handle the same anyway.
If you hit something proper, the guard often just pushes straight into the light - breaking it ... the same was what would have happened if you didn't have the guard!
( at least that was my experience on the defender! ) V8 or else ...
Post #93142 18th Nov 2011 1:23pm
The expense of replacing cracked lenses is enough to make me want to put light guards on this one too, especially if you have the clear and SC all clear lenses. If you have LEDs, god help you if you need new ones! And that's just the rears, can you imagine how expensive a front LED with Adaptive bi-xenons is going to cost?
OUCH!
They are dead easy to fit, I documented the procedure as the instructions are a bit arse-about-face.
http://www.fullfatrr.com/forum/topic132.html Discovery 4 HSE
Post #93154 18th Nov 2011 2:08pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
There are no light guards for the 2010-on front lights.
My only issue with the guards is that whilst they save the lights from moderate impacts, anything heavier risks creasing the panel itself where they attach.
Post #93162 18th Nov 2011 2:31pm
ric355
Light guards = steaming pile !
Post #93226 18th Nov 2011 7:20pm
Vogue
no way!
makes a Range Rover look like a sodding geek Sad
and it lowers their value - no way would I buy one with light guards fitted,
the only time they look half decent is the bar type on a RR Classic, the new vehicles are too streamlined for them
Post #93228 18th Nov 2011 7:32pm
ebajema
No unless you are really off-roading but then use poly-carbonate over the top of the guard. For example my FFRR has a brush guard (I would never ever had installed one but it was on and taking it off would expose the holes drilled in the front fenders to install the bloody thing Smile, plus they do help against the bloody Okadas here in Lagos) and I would "fill" the headlight section with a piece of poly-carbonate. The p-c is very strong and can take a hell of a beating and if something hits it and it cracks it takes a lot of energy and then hopefully the headlight only has a very light impact to deal with.
The light guards you see on most will only help a bit against branches but won't do anything against pebbles etc. So on a dirt/gravel road they are useless, while a full "sheet" type guard would work.
If you take the light guards, fit p-c over them they'd work a lot better but that would even be fuglier then they already are.
In other words, they are ugly as heck and I would never fit them unless absolutely necessary !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #93240 18th Nov 2011 8:35pm
bozmandb9
To me, all those bits and bobs, light guards, sidesteps, etc, just detract enormously from what is acknowledged to be a design icon. As has been stated, far from offering protection, they offer you bodywork damage in addition to a broken light. When you remove them they also require bodywork (filling and painting).
To me, they belong with stick on chrome effect trim! Thumbs Up Range Rover-less at the moment - Pining!
Post #93241 18th Nov 2011 8:39pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
No. I know the lights are expensive, but so is the whole car, you wouldn't want to wrap it up in bubble wrap.
Anyway in over 30 years of driving I have never had a broken light except in a proper accident when a cover wouldn't make any difference. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #93272 19th Nov 2011 12:57am
