![]() | Home > Maintenance & Mods (L322) > Help understanding wheel nut differences and wheel options? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
carl, the pre-facelift fullfats [2002-2005] have black nuts with a 20mm shank where as the facelift [2006 onwards] have silver nuts with a 23mm shank.
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
So the outside diameter of the nuts are bigger on the silver ones then?. If looking i would need to know the diameter of the holes to find out if the nuts are compatible?. |
the shank diameter is bigger at 23mm ..you can normally tell which wheel is pre-facelift or not.
Cheers scarey, i kind of know the facelift ones but its when im looking at aftermarket i wasnt sure if the nuts would be ok or not. |
So anyone with black nuts have the smaller of the two then? |
i would be very weary of aftermarket wheels carl, they probably wont be up to the job because of the weight of fullfat..we keep on hearing about 22'' for instance that have cracks or splits in the wheel...i know theres not that much of a choice but i would stick to landrover OE.. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
At a glance, pre facelift wheels have BMW 5mm holes between each wheel nut (something to do with tracking machines i think) whereas post facelift "Jaguar" cars only have dimples where the holes are on the earlier models...
that will be the 7 spoke 20'' craig is talking about..... |
The dimensions of the two different wheel nuts are obvious when you insert them onto the wheel (try this before mounting the wheel) New style nuts will not fit onto earlier wheels and old style nuts will be loose in the aperture of the new wheels.
That picture certainly makes things clear, thank you.
same nuts on the RRS wheels as the facelift wheels.. |
Anyone know the correct part no for the 2007 FFRR TDV8 wheel nuts?. I found i had a different one on one of the front wheels which needed a different wrench to loosen as the hex head was bigger than the rest. Needless to say i want to change it.
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
I have to admit. I still don't fully understand this. So if you want to use newer alloys from 2006 onwards on a ffrr 02-05 you can't use the same wheel nuts you have? If not which ones do you buy? If you buy the newer ones from 2006+ they are not going to fit on 2005 rr's so what do you use?
Yes the holes are different sizes......see the picture above |
