Home > Technical (L322) > no locks
m10rng
United Kingdom 2004 Range Rover HSE Td6 Java Black
no locks
went to lock my doors and the front two doors didnt lock????????
everything else locks apart from them two?
Post #92611 16th Nov 2011 11:11am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I assume they will lock with the key though? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #92630 16th Nov 2011 2:20pm
m10rng
ye, when i lock it manually they lock, but without they just stay open
Post #92639 16th Nov 2011 3:05pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Mine doesn't lock if something is left open (eg tailgate)?
Post #92640 16th Nov 2011 3:06pm
Mikeyjd
Now, that's a mystery. If you use the key in the drivers door it is still using an electrical circuit to power the lock in the passengers door. Another question, if you unlock all doors and use the key in the drivers door, do the rear doors lock as well? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #92644 16th Nov 2011 3:21pm
m10rng
yes, when all doors are open and use the key then all doors unlock except the front two?
I beleive the front door latches are needed if they are broken!!
( �74.40) each. - - Ebay
if they are nt broken then im clueless Shocked Banging Head
Post #96323 5th Dec 2011 3:53pm
