Home > Maintenance & Mods (L322) > Heated wheel
npikey
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Heated wheel
My heated steering wheel on my 06 s/c has stopped working Big Cry or tho i havent used it for some time, ive checked the fuses and hit the wheel, any ideas would be a great help, the light isnt coming on if that helps,
Cheers in advance Nick Wink
Post #92610 16th Nov 2011 10:01am
something in this thread might help..
http://www.fullfatrr.com/forum/topic3750.h...ring+wheel ... - .- -.
Post #92615 16th Nov 2011 10:33am
npikey
Thanks i'll have a look Wink
Post #92617 16th Nov 2011 11:12am
npikey
Right, ive had a look and if i have it hard on lock the heater works only when i start to straighten up does it turn off, so bad conection on the steering wheel, can i use wd40 or had i better get some electrical spray Confused
Cheers Nick
Post #92621 16th Nov 2011 12:20pm
electrical spray would be my preference.. ... - .- -.
Post #92623 16th Nov 2011 12:41pm
npikey
Right, ive had the wheel off and the only fault i can find is with the assembly that allows you to turn the steering and keep electrical contact, Crying or Very sad Part no (xzr000020) iv priced one up and they are £205 + the dreaded, whats the thoughts on swopping the wires from the heated steering for the wires on the voice control thinggy as I never use the voice button ??? any input would be gratefully received, Wink
Cheers Nick
Post #95607 1st Dec 2011 6:14pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I would try and get the part replaced rather than use the wires from the Voice button. It may be a PITA, but just think of it as another one-off cost.
Have you tried Dan as a quick google finds a few cheaper than the £205+VAT you were quoted.
Post #95642 1st Dec 2011 8:24pm
The heated steering wheel takes alot more power than the "voice button" so the power rating for the wires are lower and you will probably burn out the steering wheel slip ring...
Craig Thumbs Up
Post #95675 1st Dec 2011 10:28pm
npikey
Thanks guys, all taken on board, think i'll wait a bit as ive just spent £1200 on having the rear bushes replaced, ( Oh got a pair of rear drive shafts with dammaged ends if any one needs some Rolling Eyes ) and £744 on 4 new tyres so the wife's not happy about spending any more at the mo, Christmas is coming and she's a spending like no tomorrow Surprised, I'll have another look at the slip ring when ive got a couple of hours to remove it and pull it apart, Wink
Post #95705 2nd Dec 2011 10:00am
