![]() | Home > Maintenance & Mods (L322) > Rear suspension bushes |
You will need to remove the driveshaft to get the hub off, not easy unless you have access to an air chisel or similar to push the shaft through the hub. Also the top bush bolts are eccentric and adjust the suspension geometry, they need to be marked before removing and once new bushes fitted it is recommended to have the geometry checked.
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Thanks for the info 47p2 |
There are several posts on the forum about removing the bushes with a home made extractor, use search to find them. I 'think' mattstevenson2005 did a write up on making an appropriate tool from tubing and threaded rods.
I have the axle stands & all the gear just no experience with this car, I'm an ex mechanic. Love this car but it's bankrupting me |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
bit on the pricey side if you need parts in the future, drop me an email You can paypal direct using - www.paypal.me/duckworthparts Please supply your full name address when sending a paypal payment. https://www.facebook.com/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: robin.hall@duckworth.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models ![]() |
As an ex mechanic you should manage it in situ no problem then.
