Home > Off Topic > wiring for induction hob |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35360 |
my the kitchen project is progressing and i will soon need to wire up an induction hob..is there anybody in the 'know' that can advise me whether i can splice into my cooker [30amp ?] cable.. ... - .- -.
14th Nov 2011 4:07pm |
so thats both on one cable yes?
14th Nov 2011 4:25pm |
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 |
They both have their own cable, which then both go to one switch with one cable back to the consumer unit.
14th Nov 2011 4:34pm |
thanks for the info and advice bodsy.. ... - .- -.
14th Nov 2011 4:40pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Check the ratings on your cooker and hob before doing this. If together they exceed 30 amps then its a no no.
14th Nov 2011 9:52pm |
thanks joe..i'll be running a spur from the 'oven' switch and both the oven and hob comes to 27 amps so its within the 30 amp rating ... ... - .- -.
14th Nov 2011 9:56pm |
Have you ever seen the flash from a 27 amp blow not forgetting the bang, it makes a heck of a mess |
14th Nov 2011 10:00pm |
no, but i've drilled into a live mains cable... ... - .- -.
14th Nov 2011 10:03pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
BBBBZZZZzzzzzzzzz, FLASH!!! Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
14th Nov 2011 10:05pm |
Well that was a silly thing to do |
14th Nov 2011 10:11pm |
