Home > Technical (L322) > Park ventilation?
itguy
2006 Range Rover Vogue Td6 Cairns Blue
Park ventilation?
Hi Everyone
I've got a 06MY Vogue with the park heating system fitted (fuel burning heater) but wondered if there is a way I can get it to just do parking ventilation instead of heat?
We leave the dog in the car sometimes at this time of year and heat build-up isn't an issue but just would like to leave some ventilation on for her, as it stops the nightmare scenario that occured yesterday, when I left the sunroof open (tilt) and got the interior soaked!
Cheers
Will
Post #9213 10th Dec 2009 9:18am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
If you press the MAX button (the one with MAX and a snowflake on it) just after stopping the engine air will blow from the vents for a while, I think 15 or 30 minutes.
Post #9214 10th Dec 2009 9:33am
jope
Norway 2003 Range Rover HSE Td6 Java Black
you also can have resirculation with the fuel burning system. you have to option in the menu, aux fuel heat and resirculation. But don't know how the climate is at your place now. Here we do have -10 C degrees.... so aux fuel burner is better here these days:)
but as stated in the other post, hit the max button immediately after you have turned the key position to 0 or taken the key out. This function will start resirc air
Post #9215 10th Dec 2009 1:02pm
