Home > In Car Electronics (L322) > If I get a BMW ULF Bluetooth Module.....
mjdronfield
......what else do I need to get Bluetooth handsfree in my RR ?
Its a 2003 Vogue, without a Telephone option in the main menu......
A search on here seems to show I may need an adapter, or to rewire the plug before I attached.....
Where is the pairing button ?
Am I just wanting something thats not really feasible ?
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #91698 11th Nov 2011 6:40pm
daveo
you need a 13th generation ulf, has you car got the phone loom, its a big 54 pin plug on the right as you look in the boot..it may be tucked down V8 facelift Range Rover Autobiography 22" wheels.
Post #91713 11th Nov 2011 7:35pm
mjdronfield
Hi,
Won't get the car till Monday, so can't have a look.
Currently I'm bidding on a ULF on the bay of e......
GENUINE BMW BLUETTOTH PHONE MODULE
PART NO; 84.21 6-94552-02
Though, I may have been a bit before the event - as it were ! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #91717 11th Nov 2011 8:07pm
mjdronfield
OK............won the item at £46............
Lets hope the wiring is in the car !!
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #91738 11th Nov 2011 11:33pm
mjdronfield
Hi all,
I have read that you can't just plug the ULF module into the Range Rover wiring, even though it'll fit........
Where can I get an adapter, or does anyone know what the pin outs are ? / Should be ?
Will I need anything else for Bluetooth ?
Should there be a "pairing button" ?
Thanks for your help.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #92057 14th Nov 2011 8:57am
mjdronfield
Thats how I found out that you couldn't just plug it in, but I didn't seem to find exactly what you had to do.
I shall have another search.
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #92059 14th Nov 2011 9:06am
mjdronfield
It appears I also may need a microphone, BT antenna and the pairing button then.
http://www.fullfatrr.com/forum/topic1987.h...+bluetooth
I take it they all have to be BMW items, due to the connectors ?
Thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #92060 14th Nov 2011 9:24am
SteveMFr
Site Sponsor
Available part numbers of the Bluetooth ULF from BMW
84 21 6 934 552 end of life 06/03 1st generation
84 21 6 938 610 end of life 10/03 2nd generation
84 21 6 934 961 end of life 03/04 3rd generation
84 21 6 950 089 end of life 06/04 4th generation
84 21 6 945 387 end of life 01/05 5th generation
84 10 6 955 522 end of life 10/05 6th generation
84 10 6 969 268 end of life 04/06 7th generation
84 21 6 958 358 end of life 05/06 8th generation
84 10 6 987 546 end of life 9/06 9th generation
84 10 6 980 130 end of life 11/06 10th generation
84 10 9 133 329 end of life 01/07 11th generation
84 10 9 145 007 end of life 05/07 12th generation
84 10 9 154 358 current production 13th generation
Your PN doesn't correspond exactly to any here - typo? I assume it's a first gen unit. Won't be good for much - just try it and see what works and what doesn't tho.
The parts you need are all BMW except for the pairing button: you can either install a cradle or just use a push switch. If you search this forum under cradle+pairing, you should find a very detailed discussion on what's needed there.
Get the 2nd gen microphone.
If you don't have the loom in the car, there is a BMW retrofit loom.
Look up L322.com on the internet wayback machine and then go to 'phone kits'. There is a pinout chart on what you need.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #92079 14th Nov 2011 11:30am
mjdronfield
Many thanks.
When I was bidding on the module, I did look at your part numbers and must have had a senior moment, as I thought it may be 6th gen.
Who knows what I've bought then !!
Thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #92103 14th Nov 2011 1:52pm
