Home > Technical (L322) > Auto dim Sat Nav screen
supershuttle
I've noticed that sometimes my touch screen dims. I have convinced myself that it is not a fault but a feature, i.e. when it gets dark outside it gets dimmer to avoid me being dazzled.
But is it, or is it the next Censored bill? If it does auto dim where does the sensor live?
Thanks Thumbs Up Geoff
Post #91021 8th Nov 2011 3:07pm
Mine only dims when the lights come on
Have you checked to see if your lights come on at the same time?
Also does it dim with the display dimmer next to the lights twist switch?
Post #91022 8th Nov 2011 3:14pm
supershuttle
It's doesn't seem to be tied to the lights coming on it seems to have a mind of it's own and yes manual dimming will make it dimmer 9or brighter) whatever state it is in. Geoff
Post #91023 8th Nov 2011 3:16pm
i'm sure the sat nav dimming is linked to the sensor for the lights and that sensor sometimes gets dirty or gives false light readings hence the occasional glitch. ... - .- -.
Post #91029 8th Nov 2011 4:06pm
Johnte
Mines exactly the same, I wasn't sure if it was a fault or supposed to be like that Confused
Post #91030 8th Nov 2011 4:10pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
It may be that the light sensor is dirty. Perhaps the lights do come on aswell but it's light enough outside for you not to realise they are on..?
Makes sense that it's linked to the light sensor though. Ash
2016 SDV8 AB
Post #91032 8th Nov 2011 4:13pm
supershuttle
I am reassured, and I am not alone - thanks guys Thumbs Up Geoff
Post #91034 8th Nov 2011 4:17pm
Johnte
Anyone know where the light sensor is located ?
Post #91045 8th Nov 2011 4:53pm
in front of the rear view mirror... ... - .- -.
Post #91050 8th Nov 2011 5:24pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Sometimes I have to remind mine to dim by increasing the brightness by one notch and then reducing it - the link between lights on/ light sensor and screen brightness is fairly random for me!
Post #91051 8th Nov 2011 5:31pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
On the odd occasion my 2006 SC also has a mind of its own.
Gone - Range Rover Supercharged 2006
Post #91064 8th Nov 2011 7:31pm
supershuttle
Ah well - all good.
When I'm allowed i also can have a mind of my own Laughing Geoff
Post #91091 8th Nov 2011 9:29pm
Sad i got one of them wife's as well.... ... - .- -.
Post #91144 9th Nov 2011 7:01am
