Home > Technical (L322) > wheel nut advice - will these do?
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Hi.
I know there are lots of posts about wheel nut sizes here, but I am a bit confused now, I saw some advertised on ebay but was confused by the description where it mentions after market wheels. Would these suit me?
I will be fitting 2011 wheels on my 2003 FF
The nuts are advertised as follows.
Data >>
QTY - 16 wheel nuts, 4 locking nuts and removal key
Item - Closed Nut
Thread Type - 14x1.5mm
Hex Size - 21mm
Seat Type - Tapered
Length - 32mm
Finish - Chrome plated
Fitment - Range Rover, when fitting after market wheels such as Kahn, Wolfrace ect.
Please use the data above to ensure this item is suitable. It is important YOU check your vehicle's requirements and the wheel application before bidding.
Radius seat = U shape
Tapered seat = V shape
Flat seat = _ shape No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #90878 7th Nov 2011 7:28pm
sounds ok, have a look at the info in the wiki . ... - .- -.
Post #90893 7th Nov 2011 8:30pm
Mikeyjd
The only thing I'm to sure about is the 32mm length. I can't find the normal length anywhere so dont know if these are for standard wheels. Are some of the after market wheel types mentioned in the spec wider and needing longer bolts? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #90911 7th Nov 2011 10:03pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Here's the link. Different sized shaft on early & later nuts. As well as tapered & no-tapered.
http://www.fullfatrr.com/forum/topic1262-15.html
Gary
Post #90936 8th Nov 2011 1:44am
Mikeyjd
Yeah, I had read the Wiki, but nowhere is the actual length mentioned. Anyway I left a message on the guys eBay page and he phoned me back. Seems the nuts won't fit my car. It would appear that certain non standard wheels need an entirely different nut. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #91020 8th Nov 2011 3:05pm
