Home > Technical (L322) > Check engine light - again.....
LostInSpace
New Zealand 2006 Range Rover Vogue SE Supercharged Java Black
Had the yellow 'Check Engine Light' come on this afternoon. 2nd time its happened in a just over a month, see [http://www.fullfatrr.com/forum/topic7860.html here].
As per previous thread, engine starts and runs smoothly. The 'fix' last time was to clear the fault code and test drive, which didi not reproduce the issue, so not really a fix as such.
So, before I take it back to a stealer, any suggestions for trouble shooting?
Is it worth disconnecting the battery?
Will this clear the fault code? If so, what are the things I need to do once the battery is reconnected? Steering lock to lock, something about the sunroof, anything else?
Apologies for all the newbie questions.... 2006 Supercharged
1990 Porsche 928 GT
Post #90706 6th Nov 2011 6:03pm
daveo
what was the error last time... V8 facelift Range Rover Autobiography 22" wheels.
Post #90707 6th Nov 2011 6:18pm
bozmandb9
What was the fault code last time? Mine seems to come on sometimes with code 430, something about catalytic converter efficiency. I reset it with the IID and drive on happily. Never an issue, just slightly annoying. Great to have the IID and be able to reset it so quickly! Thumbs Up Range Rover-less at the moment - Pining!
Post #90708 6th Nov 2011 6:18pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
My SC displayed a transmission fault - limited gears error message followed by the EML lit when I turned the ignition on today, I cycled the ignition switch and the message has gone but the EML remains lit. The car drives fine, so I'm going to leave it for a few days to see if it clears itself.
Perhaps the cars protesting against all the bloody fireworks.
Gone - Range Rover Supercharged 2006
Post #90709 6th Nov 2011 6:20pm
daveo
EML dont sound like the result of a transmission fault, this would come on due something with the engine, not sure i have read that the batt probs would bring on the eml but some one on here may of had it, but my guess would be that its a fault on the engine system, check the fault again and ask for the error code.. V8 facelift Range Rover Autobiography 22" wheels.
Post #90718 6th Nov 2011 7:04pm
daveo
just noticed we have two members with the same prob.. V8 facelift Range Rover Autobiography 22" wheels.
Post #90720 6th Nov 2011 7:06pm
would an eml fault be due to an injector fail.. ... - .- -.
Post #90721 6th Nov 2011 7:10pm
JustinP
My battery was replaced less than 12 months ago, whilst it could be faulty I think it's unlikely to be the cause in my case.
Post #90722 6th Nov 2011 7:11pm
daveo
true, i think the fault is with the engine, yes could be an injector,coil or sensor but i think the best and only way is to have the fault read, V8 facelift Range Rover Autobiography 22" wheels.
Post #90723 6th Nov 2011 7:16pm
A common cause of the eml coming on on petrol engined cars is a fault with an oxygen sensor. The V8 has 4 Smile
The "fault" can often be cleared by taking out the oxygen sensors and cleaning them, if you can get them out of the exhaust in one piece, they tend to fix themselves in place.
Possibly worth a try. If it doesn't work, new sensor.
Post #90725 6th Nov 2011 7:20pm
Almost all EML lights are due to emissions, and as stated most are O2sensor problems. My last one was a bank running lean. A quick reset and LPG retune and 8months later still hasn't returned. When I have checked recently had an O2 sensor wide open error so guess I have one on the au out. Think they are about £50 each so not massively expensive. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #90728 6th Nov 2011 7:45pm
LostInSpace
@ bozman - Fault last time was running lean on bank 1-4, but I didn't get the actual code.
Don't think transmission is an issue, shifting smoothly through the gears both up and down. O2 sensors for the 1-4 bank are definitely worth checking Idea does anyone have an idiots guide?
A faulty injector would also cause a lean condition, however I suspect you would hear and feel the poor/rough running if that was the case.
Will get the fault read and respond back for info.
Slightly OT - what's an IID? Assume it's a fault reader, got any details? 2006 Supercharged
1990 Porsche 928 GT
Post #90744 6th Nov 2011 9:17pm
IID = http://www.fullfatrr.com/forum/topic7073.html ... - .- -.
Post #90753 6th Nov 2011 10:08pm
Running lean could also be an air leak on the induction side. The engine getting extra unmetered air Censored up the air to fuel ratio. Quite common on te 4.4 due to perished breather pipes but not sure about the supercharged jag engine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #90768 7th Nov 2011 7:53am
