![]() | Home > General > MY2012 FBH Cycle time |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Exactly the same as MY11. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
so is that 30 mins, or 17 ? |
Mine is 30 minutes. |
so not the same as the MY11 post "fix" |
Mine is a March 2011 build with the AGM battery from the factory and is 30 minutes. Are you an earlier build? |
you got a MY2012 with a March 11 build? |
When did I ever say I had a MY12. I just know it's the same. Technically mine is 2011.5MY according to Land Rover. You ask these questions and then moan and pick holes in responses. All I am trying to be is helpful Rambles. |
I find you are being deliberately unhelpful. Any time there is a question about FBHs, you come up with rubbish.
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 ![]() ![]() ![]() |
Mine is a September built TDV8, so MY2012, cycle time is max 20 minutes and not sufficient to heat up the cabin as it did in my TD6. RR 2012MY TDV8 AB ipanema sand
Thank you roverron.
Well sorry you find my responses unhelpful. Maybe you need to change dealer as they don't exactly seem to be dealing with your issues either.
I don't understand. With the best will in the world, when I am looking for a factual answer, how can you giving a wrong answer, and stating you are sure it is correct, be helpful ?
I am sure I'm correct. My MY11 runs for 30 mins. My friends with MY12 runs for 30 minutes. |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
Hi,
