Home > Maintenance & Mods (L322) > Slow \ Sticking suspension?
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Had my wheels swapped today for 18"ers ready for winter. When the tyre guy? asked me to put the suspension up to full height and lock it.
I tried, the indicator flashed away for a good minute, after which point i turned the engine off and got out. Walked 5 paces from the car and it immediatly shot up to full height.
Any idea what the problem is (other than calling me a fatty?) __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #89401 29th Oct 2011 3:50pm
its not been extended for a while dave, mine was the same when i first got but after a 'ups and downs' its ok now.. ... - .- -.
Post #89404 29th Oct 2011 4:39pm
DaveAngel
Cool, guess you'd probably have an answer scarey - will keep an eye on it over the next couple of weeks.
Many thanks,
Dave __________________
2015 FFRR SDV8
Post #89408 29th Oct 2011 5:01pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Ideally the car needs to be moving to make height changes. The suspension will resisit the movement of the car moving up and down, therefore requireing more preassure in the system to make the change.
The older Range Rovers P38 etc could do height changes whilst stationary, as the track (distance) between wheels does not change, earlier cars had beam axles not independent suspension.
Post #89412 29th Oct 2011 5:31pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
door open?? FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #89424 29th Oct 2011 5:54pm
fisha
you probably had your foot on the brake. V8 or else ...
Post #89429 29th Oct 2011 6:24pm
DaveAngel
I had it in park with the Handbrake on so that kind of makes sense. __________________
2015 FFRR SDV8
Post #89486 30th Oct 2011 8:54am
