Home > Technical (L322) > 06MY Removing Wing Mirror Case - help... Now fixed
GJOB
2005 Range Rover Vogue SE Td6 Java Black
I've tried following the instructions on the wiki with no success.
The 06MY has a larger puddle light that that shown in the wiki, even with brute force I've been unable to separate the housing from the front ring or the mirror.
I manage to get a small bit of movement but if I life the housing any higher it's going to crack.
Is the something different on the newer models that i'm missing?
oops, meant to post in Technical, mods please can you move for me??
Post #87548 15th Oct 2011 2:49pm
GJOB
Can nobody help? I wanted to get stuck in this weekend but don't want to smash it to pieces.
Even my LR contact was unsure.
Post #88428 22nd Oct 2011 9:43am
bump ... - .- -.
Post #88834 25th Oct 2011 8:53am
Im pretty sure the larger puddle lights mirror covers dont come off my friend... What are you trying to remove it for?
Craig Thumbs Up
Post #88840 25th Oct 2011 9:51am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I've just replaced an entire wing mirror case on 2006MY. I have the old one in the box in the garage. I will dig it out and have a look at the puddle light. Will update later.
Post #88846 25th Oct 2011 10:28am
GJOB
Thanks guys,
My need to remove the cover stems from the wing mirror glass only adjusting up and down and not left and right.
I have a pet spider living in the mechanism so I suspect the cogs are just clogged up with webs/nests.
Any help would be gratefully received.
Post #88915 25th Oct 2011 7:56pm
DavidP
GJOB,
Well i have just cut the broken front case off to have a lookand i have to agree with Cam-Tech-Craig. The rim of the wingmirror is attached with 3x small reverse philips security head screws and there are 2x large plastic plugs coming from behind the metal of the motor. These are 'rounded off' holding the rim in place. I have taken some photos of the deconstruction.
Having kooked at the wiki it is a completely different construction.
Hope it helps..
Post #89023 26th Oct 2011 5:58pm
GJOB
Excellent, thanks David, I'll PM you with my email address for the photos.
Post #89185 27th Oct 2011 6:17pm
DavidP
GJOB, I sent the photos to you. Hopefully you got them, if you need anymore then let me know.
David
Post #89373 29th Oct 2011 11:28am
GJOB
I finally got round to fixing my wing mirror motor so thought it appropriate to close this thread Wink
It was very simple in the end, the motor had failed (nothing related to spiders nests!!!). So, 2006MY:
The simple steps were:
1. Gently pull the wing mirror glass away from the housing - it just clips off
2. Remove the 2 screws hold the small plastic cover on the right hand side (for a drivers side mirror)
3. Use a Torx bit to remove the centre screw and a flat head screwdriver to unclip the motor from the metal casting.
4. Unplug the connector.
Time required: 5 minutes Exclamation
Refitting is the reverse.
I was very surprised how reasonably priced the motor was (under �30) although it was covered under the warranty Thumbs Up
With thanks to DavidP for the photos and explanation to separate the rear case from the front frame - whilst it wasn't necessary in the end I did it any way to understand how the thing was put together.
Post #110704 3rd Mar 2012 7:16pm
